Hello everyone, I have an issue with one of the drawers in my IKEA Metod kitchen. It keeps sticking and can only be opened with a lot of force. The drawer is not overloaded, but the sliding rail system doesn’t seem to be running smoothly anymore. I have already tried removing the drawer to check if something was caught in the rail profile, but I didn’t find anything obvious at first glance. The rails are the standard Metod rails with a soft-close function.
Could someone provide a detailed guide on how to properly repair the drawer so it slides smoothly again? I would also like to know if there are specific points I should pay special attention to—like worn parts or adjustment options on the rails. Additionally, I’m interested in whether a common cause for sticking involves the drawer becoming misaligned and how to prevent that.
Thanks in advance for your help!
Hello tra62, first you should check if the drawer slides are properly aligned and if the drawer fits correctly in the groove. Sometimes it helps to remove the drawer completely and clean the slides from any dirt. Then carefully reinstall the drawer to ensure it is not misaligned. If the soft-close mechanism is sticking, lightly lubricating the mechanism may help, but use only a small amount of an appropriate lubricant.
Hello tra62, unfortunately, your issue is quite common with Metod drawers, especially when they are used frequently or if there are slight installation tolerances.
First, some technical background: The sliding system of the Metod drawers is based on a ball bearing track with integrated soft-close damping. Dirt in the ball mechanism or incorrect adjustment can cause jamming. The alignment of the tracks relative to each other is also crucial because the drawer can easily skew and then jam.
I recommend the following steps one by one:
- Fully pull out and remove the drawer: Pull it completely out and carefully lever it off the tracks, paying attention to the catches underneath.
- Visual inspection of the running tracks: Check the tracks for foreign objects, dust, or rust. Even the smallest dirt particles can cause problems.
- Cleaning: Use a lint-free cloth and special furniture cleaner or mild dishwater to clean the tracks thoroughly. Pay special attention to the ball mechanism.
- Check the track fastenings: Sometimes the screws on the bottom or side panels loosen. Check and tighten them if necessary; correct alignment is important so the mechanism doesn’t run crooked.
- Track adjustment: Verify that the tracks are parallel and mounted at the correct angle. Even a slight tilt can cause skewing.
- Reinstall and test: Carefully insert the drawer and test its movement thoroughly. Open and close it several times to check the soft-close mechanism.
- Lubrication: If the tracks feel dry, I recommend a special plastic glide grease or silicone spray. Avoid oil on metal parts, as it often attracts dust.
One final question: Does the jamming occur consistently, regardless of the drawer’s position, or does it happen only in certain areas? This could indicate a specific problem with the track or localized pressure points. If you want, I can send you a guide for adjustment with measurements.
I hope this detailed description helps you!
Matthewt4825 May 2023 11:46PLOMA schrieb:
The rail system of the Metod drawers is based on ball bearing slides with integrated soft-close damping.That’s an important point, thanks PLOMA! I think a common mistake with these soft-close systems is that the damping remains engaged if the drawer isn’t installed at the exact correct angle.
In addition to cleaning and checking the slides, I recommend fully removing the drawer and carefully inspecting the rails for any possible warping or damage. Screws can loosen or bend, especially after a move or furniture transport.
If the jamming occurs only when the drawer is closed or nearly closed, sometimes applying light pressure on the drawer base while closing helps it engage properly.
reni45 schrieb:
If the soft-close function sticks, lightly lubricating the mechanism can helpHowever, you should be careful to use the right lubricant! Silicone spray is generally better than regular oil because it doesn’t damage plastic components and doesn’t attract dirt.
One more tip: It’s often useful to check the drawer front panel for any warping or excessive lateral play, which can cause jamming.
Good luck with the repair!
