I have an issue with my Ikea Metod drawer system installed in my kitchen. After some time, certain drawers no longer operate smoothly: they stick, don’t close properly, or are difficult to pull out. My specific question is: what steps should I follow if I want to repair these drawer systems myself?
I am particularly interested in how to fix common problems like sticking, scraping along the rails, or creaking noises without using professional tools. Are there any recommendations for tools or replacement parts?
Additionally, I would like to know if the drawers can be fully removed without having to dismantle the entire kitchen system.
Thanks in advance for any helpful tips and shared experiences!
To address your questions directly:
- The Metod drawers are usually attached to the runners using clip systems, so you can typically unhook them easily—for example, to clean the runners or adjust them properly.
- If the drawers stick, it’s often due to dirty or bent runners. Clean them thoroughly from dust, crumbs, or grease and check the mechanism.
- For minor repairs, I recommend a set of screwdrivers (Phillips and flathead), possibly an Allen key if something needs tightening.
- Spare parts like new runners, wheels, or clips can be ordered directly from Ikea or obtained in-store.
It’s important to remove all loads before starting the repair, meaning you should completely empty and remove the drawer. Then you can proceed step by step.
Here’s a bit of lighthearted advice 😄:
Drawers that stick or squeak can be really annoying at first – but often a little "towel yoga" helps. Just pull the drawer all the way out, pull the runners forward a little, and gently shake or move it sideways to loosen up small obstacles. No big effort needed.
Oh, and a drop of lubricant on the runner won’t hurt – but avoid WD-40, as it attracts dust. It’s better to use silicone or Teflon spray.
Sometimes the best fix is: "Take it easy, the Ikea kitchen can handle more than you think." 😉
Here is a brief guide for a common repair of Ikea Metod drawer systems:
1. Removing the drawer:
- Fully open the drawer.
- Lift and pull it out.
2. Inspect the runners:
- Check for stuck areas or bent metal parts.
- Verify that the rollers or slide rails are properly seated.
3. Cleaning:
- Remove dust and crumbs.
- If necessary, wipe with a damp cloth and let dry.
4. Lubrication:
- Use light silicone spray or Teflon oil.
- Apply only a minimal amount on the sliding rails.
5. Reassembly:
- Reinsert the drawer.
- Test the function and make adjustments if needed.
Common mistakes:
- Using too much oil as it attracts dirt quickly.
- Using coarse tools that can damage plastic parts.
If the runner is damaged, it is worth getting a replacement part from Ikea – they are usually inexpensive and help in the long run.
3. Cleaning:
4. Lubrication:
5. Reassembly:
Common mistakes:
pinJustin26 Aug 2017 17:03taahmed schrieb:
I would also like to know if the drawers can be fully removed without dismantling the entire kitchen system.Yes, the drawers can be completely removed without taking apart the kitchen cabinets. Simply lift the drawer carefully and pull it out.
