Good morning everyone, I am currently planning to get an IKEA Platsa wardrobe, which I want to design space-efficiently for my rather small hallway. My question to you is: How can I design and configure an IKEA PLATSA wardrobe to provide as much storage as possible for jackets, shoes, and other items, while taking up as little floor space as possible? Are there tried and tested combinations of different elements, such as low cabinets with attachments or specific IKEA interior fittings, that you would recommend? What experiences do you have with space-saving solutions within this series, especially for narrow or awkwardly shaped entryways? Thanks for your tips and suggestions!
Rolfje schrieb:
How can I design and configure an IKEA PLATSA wardrobe to maximize storage space for coats, shoes, and other items while taking up as little floor space as possible?Hello Rolfje, that’s a good and very specific question! My advice: make full use of the height of the PLATSA series. The modules can be stacked up to the ceiling, which saves a lot of space, especially in small hallways. For storage, you should also combine cabinets with doors and open hook rails. For example, you can plan closed compartments for shoes in the lower part and install open hooks for coats above. Interior fittings like narrow drawers or removable baskets help keep things organized without increasing the footprint.
If you have a very narrow hallway, a low cabinet under a wall shelf for hats or gloves can be useful—this way, you use the wall height above and still have enough surface space below. It’s also important to adjust the depth of the modules so they don’t extend too far into the room. I hope this helps you already!
Jeanbar schrieb:
Make the most of the height of the PLATSA series. The units can be stacked up to the ceiling, which saves a lot of space, especially in small hallways.I basically agree with that, but you shouldn’t just use the full height without considering accessibility. Hallways often have high ceilings, but the upper storage is usually hard to reach, which limits its usability. A good compromise is often to use the top compartments for seasonal or rarely used items.
Furthermore, I wonder if reducing the depth of the PLATSA units really saves space? Shallower cabinets offer less storage, and if you need more compartments as a result, you end up taking up more floor area. To me, it’s more about balancing storage volume and footprint.
What do you think?
Alberto5129 Oct 2020 10:13Hello everyone, as someone who has installed a small hallway wardrobe with a PLATSA system, I can say from experience that a well-thought-out combination of closed and open elements really makes a difference. At first, I was worried that the wardrobe would feel too dominant and overwhelm the space, but my solution was to choose light-colored fronts and place the modules mainly along the walls.
I can also confirm that the interior fittings are important: drawer inserts and adjustable shelves help a lot in using the space efficiently. For example, I included drawers for smaller accessories as well as a combination of shoe racks and hooks for jackets.
Sometimes I felt overwhelmed by all the options, but the ability to add or modify individual modules later on gives you a lot of flexibility, which I really appreciate.
LEEJU schrieb:
I would recommend choosing narrow modules and stacking them vertically.That sounds simple, but especially with narrow modules, you shouldn’t forget that very small internal dimensions reduce usability. For large coats or wider jackets, it can sometimes be too tight. Therefore, I ask: What minimum width do you consider reasonable to avoid wasting storage space?
I find that the topic of width and depth dimensions is often only briefly touched upon, even though it can be crucial for everyday practicality. That’s why I usually go for a mix: narrower side units but a central, wider compartment.
