ᐅ How can I build IKEA Metod kitchen islands with plenty of storage and workspace?
Created on: 2 Aug 2015 09:12
FOLKMAR10
Hello everyone, I am currently planning to build a kitchen island using the IKEA Metod system and want to maximize storage space as well as provide a generous work surface. My question to the community is: How do you build IKEA Metod kitchen islands with plenty of storage and work area? It is important for me that the island is functional and stable, offers enough space for frequently used kitchen utensils, and still provides a spacious, level surface for food preparation and also serves as a dining area. Tips on materials and assembly are welcome, as I want to avoid common beginner mistakes as much as possible. Are there tried and tested combinations of carcasses, drawers, and countertops? What dimensions and layouts do you recommend specifically for kitchen islands? Thanks in advance for all your input!
FABIAN_DEO
2 Aug 2015 15:30
FOLKMAR10 schrieb:
I am also planning a seating area on one side with bar stools and about 30 cm (12 inches) of overhang.
This is a common issue with kitchen islands that have seating areas. IKEA Metod cabinets are not inherently designed to support large, overhanging countertops with seating, as the load can be quite concentrated. Here are my recommendations:
- Use strong support brackets under the overhang that can bear significantly more weight than simple shelf brackets.
- Reinforce the cabinet base with an additional cross brace or wooden slats.
- The countertop should be at least 3.5 cm (1.4 inches) thick—solid wood slabs provide the best stability and a premium look.
Also, you can increase the height using taller adjustable legs if you are using a 2 cm (0.8 inch) thick countertop; alternatively, special riser feet can be installed.
Regarding the length of the island (180 cm / 71 inches), this is definitely doable, but I would combine at least four cabinets (e.g., 60 cm / 24 inches wide each), thus creating a 240 cm (94 inch) cabinet system, and provide a joint in the middle with a clamping line or metal brackets for fastening. This will add stability and prevent sagging.
Building a separate bench or sideboard is also an option, but it means losing continuous storage within the island. Therefore, I would recommend creating the seating area as an overhang and reinforcing it accordingly.
susar
2 Aug 2015 16:18
Wow, that sounds really exciting! I built my island with two 80cm (32 inch) cabinets and placed a 4cm (1.5 inch) thick countertop on top. I reinforced the overhang with heavy metal brackets, which hold up great and even look stylish! The storage space is huge, and I love the drawers and compartments that keep everything neat and organized. Your plan with 180cm (71 inch) sounds perfect—you just need confidence and good screws!
janeo
2 Aug 2015 17:05
FABIAN_DEO schrieb:
Additionally, you can increase the height by using taller adjustable feet if you are using a countertop that is 2cm (0.8 inches) thick – otherwise, you can also use special riser feet.
It is important to carefully check how the taller feet will affect stability. Often, constructions with long countertops and overhangs tend to become unstable with a higher center of gravity, which can be risky. A stable floor surface and non-slip pads under the feet are essential.
Regarding the countertop: laminate boards are lightweight but often somewhat sensitive to moisture; solid wood or composite panels (e.g., quartz composite) are more durable but more expensive. This should be considered depending on the intended use.
RADUKEN
3 Aug 2015 08:47
As an addition: use drawer slides with soft-close. Although they increase the budget, the comfort is worth it. If the island is wider than 90 cm (35 inches), seriously consider how the access from the inside is designed. At widths over 100 cm (39 inches), drawers or compartments can no longer be properly reached.
Tarbi
3 Aug 2015 09:36
FOLKMAR10 schrieb:
Are there any special installation tips for securely attaching the countertops to the cabinets?
Yes, I would add this: Use the original IKEA connectors and reinforce the attachment points with metal brackets where the countertop overhangs. Also, use screws of sufficient length to firmly connect the countertop to the cabinets. Avoid all plastic parts at load-bearing points; it’s better to rely on metal. Additionally, gluing rubber strips between the countertop and the cabinet is worthwhile to prevent the countertop from sliding.
