maximus6024 Nov 2019 08:47Hello everyone, I have a problem with my Ikea PLATSA – the furniture piece has heavy stains that cannot be removed with regular dusting. Specifically, these are dried food stains and generally stubborn dirt that has settled deep into the surface. Since PLATSA is made of coated particleboard with a matte plastic finish, I want to avoid using harsh cleaning agents that could damage the surface. My question is: What cleaning methods or products are best suited to effectively and gently clean Ikea PLATSA, even with very heavy soiling? Are there any professional tips or proven home remedies that really help without harming the furniture? I appreciate concrete and practical advice.
maximus60 schrieb:
Which cleaning methods or products work best to effectively and gently clean Ikea PLATSA even with very heavy dirt?Hey, even though PLATSA seems very sturdy, the surface is sensitive to strong solvents. It’s best to start with a soft cloth and warm water, plus a little dish soap, to loosen surface dirt first.
For stubborn stains, you can use a mixture of water and a small amount of vinegar (not too much, as vinegar can damage the surface) or mild cleaners that are suitable for plastic surfaces. Very important: don’t use scouring pads or abrasive agents, as they quickly ruin the matte finish.
And if you want to be on the safe side, test the cleaner first on an inconspicuous spot. Cleaning is a bit like cooking—trying beats studying 😉!
I can confirm the tips from the first post and would like to add the following: Ikea PLATSA consists of coated MDF or particleboard panels with a melamine-like surface. They are generally water-resistant but sensitive to strong alcohols, bleach, or abrasive cleaners.
To remove dried-on dirt, I recommend the following procedure:
- First, wipe with a microfiber cloth and slightly warm water with a pH-neutral dish soap
- For stubborn stains, you can carefully test isopropanol (alcohol) on a cloth, but do not soak or rub
- Simple home remedies like applying a baking soda paste (powder mixed with a little water) and then wiping off with a damp cloth can also be helpful
- Avoid solvents such as acetone, turpentine, and aggressive cleaners completely
This method ensures cleaning without damaging the surface and helps preserve the matte appearance.
flo56 schrieb:
For removing dried-on dirt, I recommend the following method:Thank you very much for the practical tips. I once had the experience of trying to remove a stubborn red wine stain on PLATSA using just glass cleaner – frustratingly, it made the surface glossy and looked unpleasant.
What also helped me was gently polishing the furniture piece with a dry, clean cloth after cleaning and paying attention to moisture so that no water seeps into edges or joints – sometimes that causes more damage than the actual dirt. Does anyone have experience with how to best care for the surface after cleaning to prevent such stains from becoming so noticeable in the first place?
DUUS32 schrieb:
Does anyone have experience with how to best maintain the surface after cleaning to prevent such dirt buildup from becoming too severe?That’s a very valid question. The surface of Ikea PLATSA should generally be kept dry, and liquids should not be left standing on it for long periods. Regular care involves wiping it with a damp microfiber cloth.
Products like furniture polish or waxes are not recommended for these types of plastic-coated surfaces, as they can leave residues and may damage the matte finish.
To protect against heavier soiling in daily use, it helps to clean frequently used areas immediately after use, for example when placing food on them or doing work. This prevents dirt from settling and becoming difficult to remove later.
If you follow this regularly, the surface will stay attractive and durable for longer.
