ᐅ How do I clean IKEA Metod kitchen cabinet fronts when they have greasy stains?
Created on: 7 May 2016 09:27
Gethin62Hello everyone,
I have an Ikea Metod kitchen with white fronts, which have developed some greasy stains from everyday use, especially around the stove and handles. My question is: how do you clean your Ikea Metod cabinet fronts when dealing with stubborn greasy dirt without damaging the surface? I have already tried mild dish soap solutions, but sometimes grease marks remain or the fronts look streaky afterwards.
Are there any proven cleaning products or techniques you would recommend to keep the surface clean and intact over time? I would greatly appreciate tips that are suited to the materials and surface characteristics of Metod kitchen fronts. Thanks in advance!
Hello Gethin62,
I can share some insights since I have had an Ikea Metod kitchen myself for years and have tried various cleaning methods, especially for grease stains. The key point with these fronts is that they usually have a melamine coating, which is fairly durable but sensitive to abrasive or strongly alkaline cleaners.
My approach for heavy grease:
- Always start with mild cleaners, as harsh products can dull the surface or leave streaks.
- I use a mixture of warm water and a mild dishwashing detergent that cuts grease well.
- It’s important to use a soft, lint-free cloth, such as microfiber, to avoid scratching the surface.
If that’s not enough and stains remain, I apply a small amount of rubbing alcohol (isopropanol) on a soft cloth and gently treat the affected areas. Rubbing alcohol evaporates quickly and dissolves grease without damaging the surface if used sparingly.
This is a common issue: leftover cleaner residues clump together, creating the appearance of streaks. That’s why it’s important to wipe again with a damp cloth without any cleaner after washing, then dry the surface.
One more tip: avoid sponges with abrasive surfaces! Also, scrubbing with steel wool is a no-go.
I’d be interested to know exactly what cleaning products you have used so far and how you went about it. Then I can offer more specific advice!
Gethin62 schrieb:
I have already tried mild dish soap solutions, but greasy spots sometimes remain or the fronts look streaky afterward.
reoWilhelm7 May 2016 14:03Hi Gethin62,
great question! I had similar issues with my Metod kitchen. What worked for me was to avoid using too many chemicals. Sometimes a clean microfiber cloth, slightly dampened, is enough.
If it’s really greasy, I apply a little well-diluted dish soap to the cloth and gently rub in circular motions. Always wipe again with clean water afterwards, otherwise the surfaces can quickly become streaky or greasy.
That works well for me too, but be careful: never spray directly onto the surface, always onto the cloth! Otherwise, unsightly marks can appear.
Good luck with cleaning – and always remember not to get the surface too wet, as that could damage the coating.
fidasi schrieb:
If that’s not enough and stains remain, I use a small amount of rubbing alcohol (isopropanol) on a soft cloth and carefully treat the spots.
Hello Gethin62,
I can only confirm and add to the tips you’ve received so far: If you have tougher greasy stains, you can also try a mixture of warm water and a small amount of white vinegar (about 1 part vinegar to 10 parts water). Vinegar also has a degreasing effect and is gentle at the same time.
It is very important, however, to thoroughly wipe down with clean water afterwards and to dry the surfaces with a dry cloth to prevent any vinegar residue. This is especially noticeable on white or light-colored surfaces.
That’s a really good tip that is often overlooked and can quickly cause problems with IKEA surfaces.
Sometimes it also helps to repeat the cleaning process several times if the stain is very stubborn, rather than scrubbing too hard.
reoWilhelm schrieb:
This works well for me too, but be careful: Never spray directly onto the material, always spray onto the cloth!
One more small addition regarding the use of denatured alcohol and vinegar: Both are very effective at degreasing, but they react differently with plastic coatings. Denatured alcohol is generally safe when used sparingly, whereas vinegar can cause the material to appear dull if left on for too long.
This is very important! Patience pays off and protects the surface. Additionally, the area should never be left wet after cleaning but always dried immediately.
One more question for Gethin62: Have you ever treated the fronts with a special plastic or furniture care spray? Some of these can also help to reduce dirt adhesion.
Brian schrieb:
Sometimes it also helps to repeat the cleaning process several times if the dirt is very stubborn, instead of scrubbing too hard.
