ᐅ How do I clean IKEA Metod kitchen cabinet fronts when they have grease stains?
Created on: 27 Mar 2024 09:23
Kasimirpeo
Kasimirpeo
27 Mar 2024 09:23
Hello everyone, I recently installed an Ikea Metod kitchen and have been struggling with stubborn grease stains on the cabinet fronts. My question is quite specific because I want to avoid damaging the surface with overly aggressive cleaners.
How do you effectively clean grease stains from your Ikea Metod cabinet fronts without scratching them or harming the paint or finish? Are there any particular home remedies or products that work especially well?
It would also be helpful if someone could share their experience regarding how often the fronts should be cleaned to prevent such stains from forming in the first place.
Thanks in advance for your tips and recommendations!
lisku
27 Mar 2024 11:42
Kasimirpeo schrieb:
How do you effectively clean your Ikea Metod kitchen fronts from grease stains without scratching the fronts or damaging the paint or finish?
Simply use a soft cloth with some warm soapy water. For stubborn stains, add a few drops of dish soap to the water. Never use abrasive cleaners or harsh sponges.
Josefane
27 Mar 2024 16:07
lisku schrieb:
Simply use a soft cloth with some warm dishwashing water.
That sounds reasonable at first, but I wonder if that is really enough for baked-on or older grease stains.
Has anyone checked how gentle dishwashing water actually is on the surface? The Ikea Metod fronts are often melamine-coated or lacquered.
Are there cleaning products specifically formulated for this type of material combination that are still mild enough? Or should we really stick to home remedies? I think it’s important to hear evidence or product recommendations that offer long-lasting protection, not just short-term cleaning.
Jukin
28 Mar 2024 08:36
Kasimirpeo schrieb:
How do you effectively clean your Ikea Metod kitchen fronts from grease stains without scratching the surfaces or damaging the paint or finish?
This is a common issue, and I have tried various methods. Ikea itself recommends using a damp, soft cloth with mild dish soap for daily cleaning. It is important to avoid abrasive cleaners, solvents, or harsh chemicals as they can damage the surface.
For tougher grease stains, I follow this process:
- First, gently rub the area several times with a warm, damp microfiber cloth and mild dish soap
- If stains remain, use a 1:1 solution of water and white vinegar, applying it to a cloth and wiping carefully
- Then wipe down with clean water and dry with a soft cloth
Vinegar can break down grease without harming the surface and doesn’t leave an unpleasant smell if wiped off thoroughly.
Regular cleaning is key to prevent grease buildup from drying and setting in. I recommend at least a quick wipe of visible areas after each cooking session.
