ᐅ How do I properly clean IKEA BESTA furniture without damaging the surface?
Created on: 16 Oct 2024 08:37
MepeneoHello everyone,
I have a specific question regarding "How to properly clean IKEA Besta without damaging the surface?"
My issue is the following: The BESTA fronts and outer surfaces have a rather delicate coating that quickly becomes dull or even gets micro-scratches if treated too aggressively. Naturally, I want to avoid long-term wear marks or damage caused by incorrect cleaning products or methods.
Therefore, I am looking for a cleaning tip that works reliably in practice without the need for strong chemicals or scrubbing.
Does anyone know the ideal cleaning products and procedures to use on my BESTA cabinet fronts? Also, are there any specific things to avoid in order to preserve the material quality over time?
Thank you in advance for your feedback!
For proper cleaning of the IKEA BESTA surface, I recommend the following procedure:
- Avoid abrasive cleaning agents or tools such as scouring pads, as they can damage the paint or laminate surface.
- Instead, use a soft microfiber cloth that is slightly dampened.
- For stains, a mild, pH-neutral dish soap can be applied carefully to the cloth.
- Do not use alcohol-based or solvent-based cleaners, as these can dull or dissolve the surface.
- After cleaning, wipe the surface with clean water and then buff it dry with a clean cloth.
This method is gentle, prevents micro-scratches, and helps maintain the appearance of the furniture components over time.
It is also important to consider the frequency of cleaning and usage habits to avoid letting dirt dry into the surface.
KAULIS schrieb:
Instead, use a soft microfiber cloth that is slightly dampened.This is very important – a microfiber cloth helps prevent dirt particles from scratching the surface. I would also add that before the first cleaning, you should test the cleaning agent in an inconspicuous area to ensure it does not cause any changes.
What is often overlooked: avoid standing water on the surfaces, as this can lead to swelling at the edges and cause permanent damage.
If there are stubborn stains, use lukewarm water and a mild dish soap. Abrasive scrubbing motions must be avoided; instead, clean using circular or gentle strokes.
Finally, it is recommended to dry the surfaces thoroughly to prevent water marks and to protect the furniture.
I would like to add a step-by-step approach for carefully cleaning IKEA BESTA surfaces and avoiding damage:
1. Preparation: Remove dust using a dry, soft microfiber cloth.
2. Cleaning: Dampen the microfiber cloth with lukewarm water and, if necessary, add a few drops of mild dish soap.
3. Gentle cleaning: Gently wipe the surface, avoiding pressure and abrasive movements.
4. Wiping off: Always follow up by wiping with a damp, clean cloth to remove any residue.
5. Drying: Polish the surfaces with a dry, soft cloth to prevent water spots.
Important: Do not use solvent-based or alcohol-containing cleaners, and avoid abrasive tools. Scouring powders are also off-limits, as they can damage the coating.
Common mistakes to avoid:
- Scrubbing too hard
- Spraying cleaning agents directly onto the surface, which can cause uncontrolled staining
This systematic approach helps maintain the surface’s integrity over a long period.
If light scratches do occur, some finishes can be gently treated with special polishes for plastic surfaces—but only very carefully and on small areas.
