ᐅ How do I clean grease stains from Malm furniture?
Created on: 19 Nov 2019 08:23
Devinpu63
Good morning everyone, I have a question and hope to benefit from your experience: What is the best and safest way to clean Malm furniture from grease stains?
The surfaces are often veneered rather than solid wood, so I want to avoid aggressive cleaners that could damage the finish. The stains usually come from the kitchen – oil or cooking fat that unfortunately was not wiped off immediately.
What cleaning methods have you tried that work effectively without damaging the furniture? I am also interested in tips on how to prevent such stains or treat them quickly. Thank you in advance!
LAURE-TA
20 Nov 2019 07:48
Good morning everyone, I would like to add a brief step-by-step guide for removing grease stains from Malm furniture with a foil surface:
1. Carefully dust the surface to remove any loose dirt.
2. First, gently blot fresh grease stains with an absorbent, dry cloth without rubbing.
3. Prepare a cleaning solution: 1 liter (1 quart) of lukewarm water plus 1 to 2 drops of mild, pH-neutral dish soap.
4. Dip a soft microfiber cloth into the solution and wring it out well so it is only slightly damp.
5. Gently wipe the stained area, preferably re-moistening frequently and working with the clean part of the cloth rather than scrubbing hard.
6. After cleaning, be sure to use a cloth lightly dampened with water only to remove any soap residue.
7. Finally, dry the surface with a dry microfiber cloth.
Common mistake: Many people use too much water or harsher cleaners, which can cause the foil to swell or peel.
Summary: For Malm furniture with a foil finish, use mild, grease-dissolving agents and minimal moisture, blotting gently several times instead of scrubbing hard. This way you’re on the safe side.
I hope this helps!
