ᐅ How do I clean grease stains from Malm furniture?
Created on: 19 Nov 2019 08:23
Devinpu63
Devinpu63
19 Nov 2019 08:23
Good morning everyone, I have a question and hope to benefit from your experience: What is the best and safest way to clean Malm furniture from grease stains?
The surfaces are often veneered rather than solid wood, so I want to avoid aggressive cleaners that could damage the finish. The stains usually come from the kitchen – oil or cooking fat that unfortunately was not wiped off immediately.
What cleaning methods have you tried that work effectively without damaging the furniture? I am also interested in tips on how to prevent such stains or treat them quickly. Thank you in advance!
Johnathon
19 Nov 2019 09:12
Hello Devinpu63,
a very precise and important question! Especially with Malm furniture, which typically has a painted or veneered surface, caution is advised. While grease stains can generally be removed with degreasing agents, substances like alcohol or stronger solvents can cause dull spots or discoloration.
I recommend the following approach:
1. First, gently blot the grease stain with an absorbent cloth without rubbing it.
2. Then mix lukewarm water with a drop of mild dish soap known for its grease-cutting properties.
3. Take a soft microfiber cloth, dip it into the solution, wring it out well, and wipe the stain from the outside towards the center.
4. Afterwards, wipe again with a damp cloth to remove any residue.
5. Finally, carefully dry the area with a dry cloth.
Make sure to use as little water as possible, as excess moisture can cause the wood to swell. Alternatively, some people use special furniture cleaners for painted surfaces – but be sure to check the manufacturer’s instructions here.
A quick question: Are your Malm furniture pieces covered with plastic foil or a lacquered surface? This can affect the cleaning strategy.
Devinpu63
19 Nov 2019 09:45
Johnathon schrieb:
Quick question: Are your Malm furniture pieces covered with a plastic foil or a lacquer surface?
Thank you for the detailed reply! My furniture has a white foil surface, so it’s more matte, not the typical clear lacquer. Therefore, I will carefully try your dishwashing detergent tip.
Do you also know if oil stains on such foil surfaces tend to penetrate deeply into the material or remain mostly on the surface? This would be important for the treatment.
GALEO4
19 Nov 2019 10:58
I always think it’s a bit exaggerated how careful people are with Malm furniture. Of course, you don’t want to damage anything, but honestly: these laminates aren’t that sensitive. Grease stains can usually be removed quite well with a bit of DIY skill and the right all-purpose cleaner.
What I often notice is that the fear of water just makes cleaning more complicated. Using a heat or steam cleaner? That’s way too much effort. Instead, I prefer to start with simple dish soap and water, or even regular lighter fluid for stubborn stains.
Have you ever tried using acetone or other solvents? Sure, that wouldn’t be an option for some delicate surfaces, but don’t we often just avoid cleaning stains because of too much “caution” and let them sit instead?
Maybe I’m downplaying the risks here, but honestly: sometimes it’s better to take a more pragmatic approach.
Alina67
19 Nov 2019 11:23
GALEO4 schrieb:
A steam or heat cleaner? Way too much effort.
Using steam cleaners on veneered or laminated furniture, such as the Malm series, is actually very problematic. Moisture and heat can damage the material, causing the laminate to peel or bubble.
Back to the topic: grease stains on white laminates are best treated with a mild cleaning agent. A pH-neutral household cleaner mixed with some water is recommended.
GALEO4 schrieb:
What I often see: fear of water only makes cleaning more complicated.
The opposite is true: excessive use of water leads to warping and edge damage.
Due to the laminate structure, I also advise against solvents (acetone, mineral spirits), as they can actually dissolve or dull the surface coating or laminate. There are specially formulated furniture cleaners for laminates that can be found affordably online.
My tip: always test on an inconspicuous area before treating large surfaces!
Matthewt48
19 Nov 2019 13:17
I would like to add a few tips here, especially for those who are just starting to notice grease stains on Malm furniture: In general, grease stains should be treated as quickly as possible to prevent them from penetrating the surface.
My usual approach is as follows:
1. Immediately blot with a paper towel or a dry, soft cloth.
2. Avoid rubbing to prevent spreading the stain.
3. Prepare a solution of lukewarm water and a small drop of mild soap (e.g., Castile soap).
4. Gently clean with a damp cloth, as described by Johnathon.
If the stain is not fully removed by this cleaning method, I would not recommend using harsh cleaners but rather try a microfiber polishing cloth. This usually absorbs a lot of the grease without damaging the surface.
Finally, applying a gentle layer of furniture polish designed for laminate surfaces is advisable, as it helps protect the surface from future soiling.
