ᐅ How should MALM furniture be stored properly during extended periods of non-use?
Created on: 13 Nov 2022 09:17
magama
magama
13 Nov 2022 09:17
I am planning not to use my IKEA Malm furniture for several months because we are moving soon, and the new place will not be ready until later. My specific question is: How should Malm furniture be stored properly during long periods of non-use to avoid potential damage such as warping, moisture damage, or color changes?
Are there any proven methods regarding the type of storage (standing or lying down), protection against moisture, optimal room temperature, or packaging? I am also interested in whether it is better to disassemble the furniture or store it fully assembled.
I am looking forward to your experiences and tips!
Ellis
13 Nov 2022 09:43
It is best to disassemble MALM furniture and store it flat.
Protect it from moisture and keep it in a dry place, which is the most important.
Avoid direct sunlight.
SUFOJE
13 Nov 2022 10:05
Hello magama,
your question is very detailed, which is good. Basically, I recommend completely disassembling the MALM furniture before storage. This prevents stress on the joints and helps avoid warping.
You should then clean the individual parts thoroughly and store them dry. A cool, dry room is ideal, around 15-20 degrees Celsius (59-68 degrees Fahrenheit), with a humidity level of about 50%.
It is best to avoid basements, which are often more humid or have strong temperature fluctuations, as this can damage the MDF and the surface.
To protect against dust, you can cover the parts lightly with a breathable fabric, but never wrap them in plastic sheeting, as this can trap moisture.
If you choose not to disassemble the furniture, make sure to keep the drawers and doors open to avoid trapping moisture. Hope this helps!
Espen
13 Nov 2022 10:27
Disassemble, store dry, no plastic wrap.
This is usually sufficient for MALM furniture.
Kinbu
13 Nov 2022 11:03
I would like to add that when dismantling, you should store all screws and small parts in a labeled container. This will help you avoid searching for them later.
It can also be useful to lightly treat the edges and visible surfaces with furniture wax or wood care products before storage. This protects against drying out and keeps the wood flexible.
One more tip: Never store the wood lying flat on the floor, especially not on cold concrete, as it will attract moisture.
magama
13 Nov 2022 11:45
SUFOJE schrieb:
If you decide not to disassemble the furniture, make sure the drawers and doors remain open to prevent moisture from being trapped.
Thanks, that’s a great tip! I was considering leaving it fully assembled because taking apart my cabinets with soft edges and lacquered surfaces might cause damage.
Kinbu schrieb:
Lightly treat edges and visible surfaces with furniture wax or care products before storage. This protects against drying out and keeps the wood flexible.
Can you recommend a specific product that works well with MALM finishes? They are coated, and I want to avoid anything with harsh ingredients.
