ᐅ Are there any tips for cleaning Malm furniture with a matte finish?
Created on: 1 Mar 2022 08:12
BlaMarku44
BlaMarku44
1 Mar 2022 08:12
Hello everyone, some time ago I bought Malm furniture from Ikea, which is coated with a matte clear lacquer. Now I’m wondering how to best clean these surfaces without damaging the matte finish or causing unsightly shiny spots. Are there any special cleaning tips or products that are particularly suitable for preserving the matte texture while still cleaning thoroughly? In everyday use, I usually only use a slightly damp cloth, but occasionally there are stains that need a stronger cleaning approach. I would appreciate any experiences and suggestions, including technical advice on suitable fabrics or cleaning agents.
Gino38
1 Mar 2022 08:36
For matte lacquered surfaces like those on Malm furniture, I recommend using only mild cleaning agents without solvents or alcohol. A damp microfiber cloth is usually sufficient. For tougher dirt, a drop of dish soap in lukewarm water can help. It is important to wipe the surface immediately afterward with a dry cloth to prevent water stains. Sanding or harsh abrasives should be avoided, as they can damage the matte finish and cause glossy spots.
semuneo
1 Mar 2022 09:05
I can definitely confirm the tip about using a microfiber cloth. I once had a small accident with a coffee stain on my Malm dressers and initially used a special wood cleaner – unfortunately, it left a slight sheen. After that, I switched back to gently cleaning with dish soap and water, which I believe preserved the matte finish best. This worked well for everyday stains in my experience. How do you handle more stubborn stains? I still have a few unresolved ones that sometimes bother me.
Deoma
1 Mar 2022 09:25
For stubborn stains, I use a slightly dampened eraser. However, be careful not to rub the paint too hard. In addition, I only remove stains with alcohol in inconspicuous areas, as it can damage the matte finish.
Bilujon
1 Mar 2022 09:43
A tip from me: Avoid using harsh cleaning agents or abrasive sponges. Instead, use only soft cloths and a mild soap solution. This protects the paint and maintains an even matte finish.
TARAON
1 Mar 2022 10:17
MDF with matte finish and stains? Don’t worry! 🙂 My secret tip: First, wipe it with warm water and a soft cloth. If that’s not enough, use a mild drop of dish soap—but sparingly! Then let it dry thoroughly. And very important, avoid household cleaners containing ammonia or alcohol, as they often cause more harm than good. This way, the matte finish stays nice and doesn’t become too shiny ;-)
