ᐅ How can I build IKEA Metod kitchen cabinets with plenty of storage space so they are sturdy and stable?
Created on: 15 Sep 2022 08:37
PLO_MARIEL
I am planning to build a kitchen soon using IKEA Metod cabinets. My main concern is to have as much storage space as possible while ensuring the entire construction remains stable and durable.
My questions for the experienced users here: How do you build Metod kitchen cabinets with a lot of storage space without compromising stability? Are there any tips for the positioning of cabinets, fasteners, or additional reinforcements?
I have read that some people use extra materials like metal brackets or wooden strips to strengthen the structure—is this necessary, or is it only recommended under certain conditions?
Also, I am interested in whether having many drawers or shelves causes weight-related issues and how to prevent them.
Thanks in advance for your insights!
I would be very cautious about relying solely on the drywall you described. It hardly supports any of the weight of the cabinets and their contents.
It is important to choose long screws that anchor securely into the brick, so the length should be at least the insulation thickness plus the drywall thickness plus 6-8 cm (2.5-3 inches) into the brick. Metal expansion anchors or heavy-duty plastic wall plugs can help here.
Another proven method is to mount a sturdy wooden or metal subframe in front of the wall, which then serves as the mounting point and also distributes the weight more evenly.
To connect the individual cabinets, it’s best to use the original IKEA connectors, which create a solid unit. It is also ideal to screw the back panel fully in place rather than just slotting it in – this significantly improves stability.
If you like, I can also give you more detailed advice on drilling and anchor selection, as that is often the critical point.
I can only agree with the previous speaker, it’s really important to anchor the beams or masonry behind the insulation!
Important: Don’t get discouraged if the brackets don’t fit perfectly the first time – a little patience while drilling is your friend!
And just imagine, in the end you’ll have the storage space of your dreams – it’s definitely worth the effort!
Also, I really like the option of reinforcing the corners with metal brackets. I installed them myself and it feels very sturdy. So go for it! Don’t be afraid, you can do it!
Palenar schrieb:
Metal brackets are most effective when installed at load-bearing points, such as the lower and upper corners, as well as under wide cover plates.That may be true, but honestly: who wants to see oversized brackets clearly visible in a modern kitchen? IKEA already emphasizes minimalism – if you spoil the visible appearance with brackets like that, you might as well forget the entire concept.
I fear many of the considerations here are important for those who don’t want professional installation and prefer to improvise somehow.
gilen schrieb:
Another proven method is to attach a sturdy wood or metal subframe to the wallIf you go that route, it hardly counts as IKEA anymore – you might as well build everything yourself. What’s clearly missing here are solutions that integrate neatly and aesthetically with IKEA’s specifications and design.
PLO_MARIEL schrieb:
How exactly would you position such brackets or moldings? Only at the corners or also across the back panel?The best practice is to install brackets at the lower corners for floor attachment and at the top on the sides. Crossbars on the back panel are only necessary in special cases when the rear panel is insufficient or the cabinets stand freely.
theota schrieb:
Who wants to see oversized visible brackets in a modern kitchen?That’s a valid point, and depending on personal preference, brackets should of course be installed so they don’t create a visual distraction.
PLO_MARIEL, my advice: focus on solid wall fixing and securing the cabinets to each other. When everything fits well, visible reinforcements are not necessary.
