ᐅ How can I build IKEA Metod kitchen cabinets with plenty of storage space so they are sturdy and stable?
Created on: 15 Sep 2022 08:37
PLO_MARIELP
PLO_MARIEL15 Sep 2022 08:37Hello everyone,
I am planning to build a kitchen soon using IKEA Metod cabinets. My main concern is to have as much storage space as possible while ensuring the entire construction remains stable and durable.
My questions for the experienced users here: How do you build Metod kitchen cabinets with a lot of storage space without compromising stability? Are there any tips for the positioning of cabinets, fasteners, or additional reinforcements?
I have read that some people use extra materials like metal brackets or wooden strips to strengthen the structure—is this necessary, or is it only recommended under certain conditions?
Also, I am interested in whether having many drawers or shelves causes weight-related issues and how to prevent them.
Thanks in advance for your insights!
A very detailed concern – it’s good to specify it so clearly.
In principle, for Metod systems, wall mounting of the cabinets is the most important factor for stability. I recommend securing the main load-bearing force with solid, properly anchored screws in the wall.
Additionally, heavy cabinets, such as those with many drawers, should be placed at the bottom to keep the center of gravity low.
Using the original IKEA connectors is also advisable because they are precisely designed and enhance stability.
Metal brackets or wooden strips are especially helpful when wall mounting is difficult or as additional support for very large units.
PLO_MARIEL15 Sep 2022 11:47SONLIS schrieb:
I recommend securing the main load by using solid, properly anchored screws in the wall.This is an important point – how exactly can you ensure that the screws are anchored in load-bearing material? In my case, it's an exterior wall, but I am uncertain because of the insulation and wall construction. Is it sufficient to use longer screws here, or should special anchors be used?
SONLIS schrieb:
Metal brackets or wooden battens are especially helpful when wall mounting is difficult, or for very large elements as additional support.How exactly would you position such brackets or battens? Only at the corners or also across the back?
I would like a neat solution without visually disturbing reinforcements.
Good morning,
I would like to provide some detailed additions to establish a technically solid foundation for this topic.
1. Wall Fixing:
- Especially with exterior walls that have insulation, it is crucial to thoroughly analyze the wall structure. Ideally, use a stud finder to locate load-bearing studs or support framing.
- For screws, it is recommended to use heavy-duty anchors that are certified for the masonry behind the insulation.
- Longer screws are beneficial, but only if they reach into the structural framework.
2. Positioning of Cabinets:
- Place heavy base cabinets directly on the floor to maximize stability.
- Wall cabinets should not be overloaded whenever possible.
3. Reinforcements:
- Metal brackets are most effective when installed at load-bearing points, such as lower and upper corners, as well as under wide countertops.
- Cross battens at the back can help if the cabinets stand free or do not fully rest against the wall; the back panels of Metod cabinets tend not to provide sufficient stability on their own.
4. Additional Tips:
- Choosing adjustable shelves with slightly greater depth can help distribute the load better.
- Avoid simply assembling cabinets next to each other; connecting multiple units together greatly increases overall stability.
Do you already have a clear understanding of the wall materials you are dealing with? This information will help provide even more targeted recommendations.
1. Wall Fixing:
3. Reinforcements:
4. Additional Tips:
PLO_MARIEL16 Sep 2022 08:35Palenar schrieb:
Do you already have a clear idea of which wall materials you will be dealing with?Yes, thanks for asking, that is actually important! The wall is an exterior brick wall about 40 cm (16 inches) thick, with mineral wool insulation attached to it, followed by drywall. The cabinets are intended to be mounted on the drywall surface.
I am therefore unsure whether the anchors will provide sufficient support on their own or if an additional substructure should be installed. Alternatively, screws could be driven from the inside through the drywall into the brick – but for that, I would need to know the minimum screw length required.
For storage, I plan to install several tall cabinets side by side, including drawer units that will need to support several kilograms.
