ᐅ How do I build Ikea Metod cabinets with sliding doors for multifunctional rooms?
Created on: 15 Feb 2015 08:23
lisfoHello everyone,
I am planning to integrate IKEA Metod cabinets with sliding doors into my multifunctional room to allow flexible use of the space. Since the room will serve both as a home office and a guest area, it is important for me to build and arrange the cabinets in a way that maximizes storage while ensuring the sliding doors operate smoothly without losing too much space due to door movement.
My questions are:
- Are there any specific installation tips for fitting Metod cabinets with sliding doors, especially regarding stability and alignment?
- What should be considered when using these cabinets in a multifunctional room to maintain maximum flexibility?
- Are there any accessories or modifications you would recommend to make the sliding doors easier to operate or more durable?
I look forward to hearing about your experiences, detailed assembly instructions, or practical advice! Thanks in advance.
My questions are:
Hello lisfo,
Great that you want to use Metod cabinets with sliding doors in a multifunctional room. I have supported a few projects like this and am happy to share some structured tips:
1. Preparation:
- Measure the room precisely and plan the cabinet configuration with multiple modules so you can flexibly meet your storage needs.
- Be sure the floor is level, as uneven floors can cause the sliding doors to stick.
2. Assembly:
- First, install the base elements of the Metod cabinets securely and aligned. Definitely use a spirit level to ensure straight lines.
- For the sliding doors: follow the IKEA assembly instructions exactly, but also check during the installation of the running rails that they are perfectly parallel.
3. Stability:
- Reinforce the cabinet base shelves for heavier loads, for example with additional metal brackets, especially if the room will be used intensively for multiple functions.
4. Sliding doors:
- Use rollers made of plastic or nylon; these are durable and run quietly.
- After installation, it’s worth opening and closing the doors several times, then adjust the running rails if necessary.
5. Flexibility:
- Metod offers modular system accessories such as various shelves, drawers, and inserts to make your system adaptable.
- Consider interior lighting with motion sensors that activate when the doors open—this makes using the cabinets more convenient.
Finally: avoid using too narrow rails and pay close attention to proper alignment, otherwise the sliding doors may jam.
Hope this helps! If you like, I can also provide advice on accessories.
1. Preparation:
2. Assembly:
3. Stability:
4. Sliding doors:
5. Flexibility:
Hey lisfo,
I want to bring a bit of lightness to this – it sounds like an exciting project! 😄 Sliding doors are great for saving space while still creating something stylish.
A small tip from me, besides using the right screwdrivers: apply a little assembly grease or plastic sliders on the tracks if the doors stick. Not too much, otherwise it gets messy, but enough for smooth gliding.
Also, if your room is meant to serve multiple functions, consider building the modules so you can easily move or rearrange them if needed. The IKEA system is quite practical for this, thanks to its plug-and-play design.
I’d love to hear how it goes – it’s always fun to see projects like this! 😉
Hello lisfo,
I would like to address some basic points that are especially important for multi-room use.
First of all, I recommend taking precise measurements during the planning phase – which you probably already have – and then considering how the cabinet doors can be opened most effectively without getting in the way during work or while in the room. Sliding doors are ideal here because they do not swing outward.
This advice is really important because, especially with frequent use, jamming can cause a lot of frustration.
Furthermore, I suggest fastening the Metod elements directly to the wall to ensure stability and prevent tipping, particularly when guests are using the room.
Last but not least: Pay attention to the screws and anchors you use, depending on whether your walls are made of concrete or plaster – this is crucial for durability.
If you need help choosing the right doors or accessories, feel free to get in touch.
harold schrieb:
Finally: Avoid rails that are too narrow and make sure they are properly aligned, as sliding doors can otherwise get jammed.
suru61 schrieb:
a little assembly grease or plastic sliders on the tracks if the doors stick.That’s a very good tip. I would like to add that it is essential to pay attention to the quality of the rollers. Sometimes IKEA supplies plastic rollers that wear out quickly with frequent use. In specialist stores, you can often find replacement rollers made of high-quality nylon, which are much more durable.
geneda schrieb:
Furthermore, I would recommend fixing the Metod units directly to the wall so they stand securely and don’t tip over under load.I want to emphasize that again! Stability is crucial, especially in multifunctional rooms. Additionally, I recommend not underestimating the weight of filled cabinets – high loads at the back can cause tipping.
One more tip regarding doors: when assembling the sliding door frames, check that all parts fit flush together, as small misalignments at the edges can quickly cause the doors to stick.
If you like, I can also create a small checklist for the assembly.
