ᐅ How can I install IKEA Metod cabinets in tight spaces to make them functional and space-efficient?
Created on: 16 Dec 2023 20:37
laloko
laloko
16 Dec 2023 20:37
Hello everyone, I would like to start a discussion on the topic: How can I assemble IKEA Metod cabinets functionally and space-efficiently in tight areas?
I have a small kitchen with only a few square meters and want to maximize storage space with Metod cabinets despite the limited room. I am especially interested in options for optimal interior organization, the choice of cabinet sizes and systems, as well as tips on how to make the best use of the available space without it becoming too cramped or impractical.
Additionally, I would find it helpful if you could share your experiences with suitable accessories, such as drawer inserts or pull-outs, that make sense in tight spaces.
I have some basic knowledge about the Metod series, particularly regarding cabinet widths and heights, but I want to make sure I don’t make any mistakes during assembly that I might regret later.
Looking forward to your advice!
TRADI
16 Dec 2023 21:12
Hello laloko,
With limited space, the most important thing is to measure the entire area precisely and then plan with the appropriate cabinet widths and heights. The Metod series offers widths of 20, 40, 60, and 80 cm (8, 16, 24, and 32 inches), which greatly helps to stay flexible.
I recommend measuring everything carefully first, including niches, corners, and doors. Then you can try out different cabinet combinations virtually using a planning tool (IKEA provides one).
Regarding storage and functionality: pull-outs, especially full-extension drawers, are invaluable to easily access items stored at the back. Drawer inserts and flexible adjustable shelves are also recommended to better organize the storage space.
For very tight rooms, tall wall cabinets with shallow depth are practical because they provide storage without visually overwhelming the space.
Finally, I would always assemble step by step: first fix the cabinet carcass to the wall, then install the pull-outs, and only attach the fronts at the end. This way, you can still make fine adjustments to the cabinets.
What are the exact dimensions of your room? Do you already have a specific floor plan?
GALENKU
17 Dec 2023 07:46
Take precise measurements and plan using 20, 40, and 60 cm (8, 16, and 24 inches) modules. Internal drawers improve the use of narrow storage spaces. Prefer taller cabinets to make use of vertical space. Avoid deep wall cabinets to keep walkways clear.
Laukau5
17 Dec 2023 10:09
Hello laloko, I would like to elaborate a bit more on planning in very confined spaces, as mistakes easily occur here that are difficult to correct later.
First, I recommend measuring not only the floor area but also the exact depth and height of the room, as well as adjacent doors or windows. Pay special attention to wall sections that may not be completely flat – this can affect precise installation.
For Metod cabinets, you can combine widths in 20cm (8 inch) increments and vary the heights between 60, 80, and 100 cm (24, 32, and 40 inches) for base units. In small kitchens, I often prefer a combination of 40- and 60-cm (16- and 24-inch) cabinets, as they fit well into niches and at the same time match standard sizes for accessories.
Functionality is best achieved by using pull-out drawers that utilize the full depth instead of just hinged doors, where storage space at the back is often lost. For corner areas, carousel or LeMans cabinet solutions are useful with Metod – however, these require sufficient space, so for very tight spaces the use of corner cabinets with LeMans pull-outs should be carefully considered.
I also recommend coordinating the accessibility of work surfaces, sink, and cooktop carefully with the cabinet positions during planning. Cabinets should not be placed so close together that doors and drawers obstruct each other.
Drawer inserts such as cutlery trays, bottle holders, or flexible dividers increase organization and especially help maintain clarity in small kitchens.
Finally: Are you flexible regarding the room layout, or is the kitchen fixed in place? This will influence the choice of cabinet heights and arrangement.
TRADI schrieb:
What exactly is the size of your space? Do you already have a concrete floor plan?
That would be helpful to provide more targeted advice.
laloko
17 Dec 2023 13:21
Thanks in advance for your initial responses.
About the room: The kitchen is just under 4.5 m² (48.4 ft²), rectangular, about 260 cm (8.5 ft) wide and 175 cm (5.7 ft) deep. The door is on the short side and opens inward, so the base cabinet in front definitely needs to leave space for the door.
The room is fixed, no structural changes are possible. Therefore, compact cabinets are planned on the long walls, left and right. I would rather avoid corner cabinets, as they visually make the space feel more cramped.
The goal is to have enough storage for dishes, pots, and small appliances. The countertop workspace will have to be rather limited.
I understand that 40- and 60-cm (16- and 24-inch) wide METOD modules make sense. However, I am uncertain about the height: 80 or 100 cm (31.5 or 39.4 inches)?
Laukau5 schrieb:
Drawer inserts like cutlery trays, bottle holders, or flexible dividers improve organization and make it especially easier to keep track in small kitchens.
Can you recommend anything concrete that is functional given the limited depth and width? And what about internal pull-outs in 40 cm (16 inch) deep cabinets? Are they worthwhile, or does that waste storage space?
Dopoki
18 Dec 2023 09:03
Good morning,
with a kitchen area of 4.5 m² (48.4 sq ft) and dimensions of 260 cm (102 inches) wide by 175 cm (69 inches) deep, every centimeter counts. Here are some precise recommendations:
- Cabinet heights of 80 cm (31.5 inches) provide an ergonomic working surface, while 100 cm (39 inches) can make it more difficult to work comfortably, especially in small spaces.
- 40 cm (16 inches) modules are suitable for dishes or smaller appliances, while 60 cm (24 inches) modules work better for larger pots and pans.
- Internal drawers in 40 cm (16 inches) deep cabinets are useful if they are fully extendable. They allow better access compared to fixed shelves.
- Cutlery trays or modular inserts (e.g., for spices, plates, or small kitchen appliances) help keep things organized, reduce search times, and prevent wasted deep storage space.
- Avoid cabinet depths over 60 cm (24 inches) in tight spaces, as this can restrict walkways.
As accessories, the Metod organizer inserts from IKEA are recommended, especially the adjustable inserts for drawer widths of 40 and 60 cm (16 and 24 inches).
laloko schrieb:
Can you recommend something concrete that is especially functional with limited depth and width? And what about internal drawers in 40 cm deep cabinets? Are they worth it, or is more storage space lost?
Using drawers there is definitely worthwhile. Storage losses are minimal if the drawers are fully extendable.
