ᐅ How can I build IKEA Besta into a high-quality furniture piece for sloped ceilings?
Created on: 22 Jan 2020 08:37
remuzarHello everyone, I am facing the challenge of modifying an IKEA Besta shelving unit to fit perfectly under a sloped ceiling while maintaining a high-quality appearance. The particular difficulty is that the slope is quite steep, and I want to use as much storage space as possible efficiently. Stability and an upgraded look compared to the standard version are very important to me. Does anyone have experience modifying Besta units for sloped ceilings? What adjustments to materials, construction, or installation have proven effective? How can the furniture piece be made especially durable and elegant, possibly with additional cladding, fittings, or surface treatments? I look forward to your tips and practical advice, thank you!
sarGabriel22 Jan 2020 09:12I would first measure the exact slope and then cut individual shelf parts accordingly. Use a narrow OSB board as a precise cover and paint it with matte paint for a refined look. Secure everything with metal brackets for stability.
Hello remuzar, I completely understand your challenge. Sloped ceilings can be tricky because standard furniture rarely fits perfectly without adjustments. My advice: - Measure the slope precisely at several points to detect any irregularities. - Use sturdy metal brackets to connect the cabinet and the slope securely. - Instead of the original back panel, you can use a thin plywood panel that you adapt to the slope. - Paint or stain the surfaces to give the shelving a more high-quality appearance. Basically, the Besta system offers a lot of flexibility thanks to its modular design. One tip: reinforce the shelves if you plan to store heavy items. If you like, I can also share examples of how I did this.
A sophisticated solution for Besta furniture on sloped ceilings relies on precise planning and material selection. Important: - Use a detailed measurement of the slope, including ceiling and wall contours. - Cut the side panels from MDF or multiplex plywood accurately to match the slope. - Use sturdy connectors (e.g., wooden brackets, screw anchors). - For a high-quality appearance, I recommend a continuous trim made of real wood veneer. - The surfaces should be treated with two-component lacquer or high-quality wood stain. - Inside, you can work with shelves made of solid wood or powder-coated metal. This ensures durability and an elegant look. The Besta system is generally load-bearing, but additional reinforcements on the lower sides of the cabinets are advisable.
DIDOGU schrieb:
Use a detailed measurement of the slope, including ceiling and wall lines. That’s a good point, so far I’ve only measured the slope at two points. That will probably not be sufficient.
Ianlau schrieb:
Reinforce the floors if you have heavy storage, if necessary. What kind of reinforcement do you specifically recommend? The system actually uses chipboard panels, which I think are not very strong within the modules. Would an additional panel or side bracing be an option?
I’m also curious about how to create a visually uniform front when I need to adjust individual elements by trimming them to fit the roof slope. Do you have experience with clever cover strips or handle rails to make this look high-quality?
Regarding your question about reinforcing the floors: I used plywood panels with a thickness of 15mm (0.6 inches) as an additional support or replacement. This feels much more stable than the original chipboard panels. If material thickness is an issue, I reinforce the floors with metal angle profiles underneath, which are directly attached to the side walls.
For the visible front: You can work with suitable MDF trim or solid wood strips. It is important to use a consistent color tone or finish, as this creates a harmonious look even with cut edges. Aluminum or stainless steel handle strips also give a high-quality impression and help conceal edges. If possible, avoid visible screws or use cover caps; this greatly improves the overall appearance.
