I am planning to transport an Ikea Brimnes furniture piece, but I’m unsure how to best prevent damage during the move. The furniture consists of several parts, including doors, carcasses, and back panels, which seem to be quite delicate.
Are there any proven methods or precautions to keep in mind specifically when transporting a Brimnes piece? How can I best protect the sensitive surfaces and edges from scratches, dents, or breaks?
I look forward to your tips and experiences!
Hello Fragla,
Your question is very well put and important for anyone planning to transport the Brimnes. In general, you should consider the following points when transporting:
- Packaging: It is best to pack the individual parts in the original boxes, as they fit perfectly and provide protection.
- Padding: To ensure extra protection, it is recommended to wrap the surfaces with blankets or bubble wrap, especially the edges and door fronts.
- Securing: Load the parts so they cannot shift during transport, for example, by using ratchet straps.
- Care when loading and unloading: It is best to work with two people to lift the furniture safely and avoid impacts.
Even though the material appears sturdy, the surfaces—especially the white doors made of coated particleboard—are delicate. I hope this helps!
jordanvin29 May 2017 09:05Hey Fragla!
I recently transported a Brimnes myself and was a bit worried about any damage. My advice: use every type of protective material you can get! Especially blankets and foam edge protectors are great for preventing scratches and bumps.
Also: distribute the weight evenly so nothing shifts during the trip. I was really impressed with how stable everything arrived when properly packed.
Good luck, you got this! 😊
jordanvin schrieb:
Use any kind of protective material you can get! Especially blankets and foam edge protectors are great for preventing scratches and bumps.That is definitely good advice, but the type of transport vehicle should also be considered. It doesn’t help much if you protect the Brimnes well, but the car, for example, doesn’t have a flat loading floor or the furniture pieces are placed awkwardly.
I would also suggest checking the furniture for edge protectors, as these often provide effective protection.
Fragla, how exactly are you planning to transport the Brimnes? My impression is that the transport method is crucial in determining the risk of damage.
BLAKEO schrieb:
Fragla, how exactly are you going to transport the Brimnes?Thanks for the tip. I plan to transport the piece of furniture in a mid-sized station wagon. The cargo area is flat but not very large, so some parts will have to be stacked on top of each other. I definitely want to pad the delicate surfaces, but I’m unsure how to securely stack or fix them without putting stress on doors or back panels.
What do you think is the best approach when space is limited? Flat and stacked, or leaning the individual parts at an angle? I want to avoid warping the doors or breaking edges.
Sinan-meo30 May 2017 07:44A practical approach to transportation:
- Store individual parts as flat as possible, but not directly on top of each other; separate them with solid layers such as sturdy cardboard pieces or thick blankets.
- Store doors vertically if possible, as this reduces pressure marks.
- Back panels are often thin and quite flexible, so they should not be placed under heavy items.
- Secure everything with tension straps or strapping systems to prevent shifting.
This way, pressure on sensitive areas is minimized, and the risk of deformation is reduced.
