ᐅ What modifications have others made to the Ikea BRIMNES?
Created on: 13 Sep 2018 20:12
Metatu
Metatu
13 Sep 2018 20:12
I recently purchased some furniture from the Ikea Brimnes series and am thinking about how to better customize the pieces to suit individual needs. I’m especially interested in practical or aesthetic improvements that others have made to BRIMNES.
Maybe it’s about additional reinforcements, modifications for more storage space, or clever organization tips for drawers and compartments? Conversions that make the furniture more durable or stylish would also be interesting.
What improvements have others made to Ikea BRIMNES? I look forward to your experiences and ideas.
JAFUHAU
13 Sep 2018 20:45
Hello Metatu,
I think your question is great because the BRIMNES series often has a few weaknesses that other users have solved with their own modifications.
In my case, the drawers are a bit wobbly, so I installed metal slides. Considering how often the drawers get stuck when opening and closing, that really helped me.
I’ve also heard about using screw extensions on the carcass because the original screws sometimes don’t hold deep enough.
I’m also curious if anyone has improved the appearance with paint or films without losing the character of the furniture.
bijo54
13 Sep 2018 21:03
- Metal drawer slides are common.
- Additional back panels increase stability.
- Some use furniture legs for extra height and airflow underneath.
sihau
13 Sep 2018 21:25
The most common improvements address the following points:
- Reinforcing the side panels with additional battens or brackets to increase stability under load.
- Attaching self-adhesive felt pads under the feet to protect the floor and reduce wear when moving the furniture.
- Replacing the drawer slides with metal ones, which significantly extends their lifespan.
Another useful addition is installing LED light strips inside to improve visibility, especially in darker environments.
TEBILO
13 Sep 2018 22:02
Based on my own experience and a bit of deeper analysis, here are some improvements:
For my BRIMNES dresser, I replaced the drawers’ original slides with metal runners after noticing that the standard guides tend to wear out easily. I adjusted the runners to fit the width and secured them with 3mm (1/8 inch) drill holes—note that the holes must be drilled very precisely to prevent the drawers from sticking.
Additionally, I attached small plastic spacers to the bottom of the side panels to allow minimal air circulation and help prevent moisture damage when the furniture is placed in a more humid room.
Another tip for multi-purpose modifications: I reinforced the top shelves with a thin MDF board, which I then painted to create a smoother and more durable surface. This way, you can place heavier items on top without the original panel bending.
These are mainly practical measures I prefer for making furniture more robust. I’m curious how others have handled painting and changing decorative surfaces—are there any tips on that?
WARREN
13 Sep 2018 22:18
- Replace metal drawer slides more often.
- Attach furniture feet for better stability.
- Reinforce back panels with additional battens.
