ᐅ How do I attach IKEA Metod baseboards/skirting boards to different types of flooring?
Created on: 21 Dec 2024 08:37
Nura2Hello everyone, I am currently planning to install my IKEA Metod kitchen plinths, but I’m unsure about the best approach for different types of flooring. So my specific question is: What is the best way to attach the IKEA Metod plinths to various floor coverings such as tile, hardwood, vinyl, or concrete? I’m especially interested in reliable methods that ensure the plinths stay firmly in place but can also be easily removed if needed without damaging the underlying floor. Are there any special adhesives, clips, or screws that work particularly well for this? Additionally, I would like to know if there are any specific techniques or preparations for uneven floors to mount the plinths flush. Thanks in advance for your tips and experiences!
For tiles, I recommend using special adhesive or double-sided mounting tape to simply press the strips in place. For parquet flooring, it’s better to use clips or screws with anchors to avoid damaging the floor. Vinyl can be fixed with adhesive, and concrete with anchors and screws. Uneven floors should be leveled beforehand, for example with filler compound.
I would like to go into more detail on this topic, as attaching Metod baseboards on different floor types can be quite tricky. Basically, there are three common fastening methods: clip systems, screws with anchors, and mounting adhesive.
- For tiled floors, I recommend avoiding screws to prevent cracks. Self-adhesive clips or special mounting tapes with strong adhesive power, which can also be removed, work better.
- Parquet requires careful fastening, ideally small screws with appropriate anchors that are not set too deep. Alternatively, clips that hold the baseboards without perforating the floor are a good option.
- For vinyl and other soft coverings, you should neither nail nor screw. In this case, polyurethane-based mounting adhesive works well because it remains flexible and adapts to the flooring.
- Concrete is robust: anchors and screws work best here, but you need to be mindful of the dust created when drilling.
I would be interested to know exactly what type of flooring you have and how level it is. Unevenness can be evened out with leveling compound, otherwise flexible seals or narrow wooden wedges can help compensate for irregularities.
I completely understand that the combination of different floor types and attaching baseboards can cause uncertainty. I felt the same way when I renovated my kitchen. In the end, I chose clip systems because I wanted more flexibility and a lower risk of damage.
I hope this helps, and that you find the right solution for your floors. It’s important that the method is both stable and gentle on the floor, otherwise you’ll only regret it later. If you like, I can also share my experience with certain brands of adhesive that have held up really well.
Dilen schrieb:
I would be interested to know exactly what type of flooring you have and how it is installed.
To return to the question of how to best attach IKEA Metod baseboards on different types of flooring: I recommend first preparing the subfloor well. For harder surfaces like tile or concrete, using screws and wall anchors is practical and secure. Avoid using anchors that are unnecessarily thick to prevent the baseboard from wobbling. For parquet flooring, use small clips, which can be supplemented with construction adhesive on the back of the baseboards to provide extra stability without damaging the floor.
Several colleagues and I have had good experiences with the following steps:
- First: clean the floor and remove dust.
- Level out any irregularities with a suitable filler.
- Install clips at intervals of 30 cm (12 inches).
- Snap the baseboards onto the clips and, if needed, additionally secure them with some construction adhesive.
It is also important not to press the baseboards too firmly against the floor in case there is any movement in the flooring. I am curious whether you have underfloor heating in the kitchen, as that also influences the choice of materials.
Good morning! I would like to add some additional points here, especially regarding preparation and the specific challenges of uneven floors, which many people often overlook.
Tiles and concrete are relatively straightforward: you can use anchors, but only if you are sure that the drill holes won’t cause any cracks. A good drill and a steady hand are essential. For tiles, there are special tile drill bits designed to avoid damaging the glaze.
For vinyl or parquet flooring, it’s better to use adhesive methods instead, as screws can easily cause damage. If the floor trolley is uneven, you can use small wedges hidden behind the baseboards.
Additionally, I recommend attaching clips directly to the inside of the baseboard when using them, so the baseboards can be easily removed later. An important tip: always work with a spirit level and measuring tools to ensure the baseboards are installed perfectly level, as this makes all the difference.
I’m also interested in how large the areas you are covering are, and whether there are any corner areas you find particularly challenging?
