ᐅ How can I securely and invisibly attach IKEA Metod baseboards (kickboards)?
Created on: 21 Jun 2020 09:23
ARJENI recently assembled an IKEA Metod kitchen and am now facing the challenge of securely attaching the toe kicks while keeping them as invisible as possible. The original fastening methods with clips are straightforward, but I’ve noticed that the toe kicks tend to wobble slightly, especially at the corners and joints. Therefore, I’m looking for tips or techniques to fasten the Metod toe kicks more securely without visible screws or brackets. I’m mainly interested in a professional solution that has little to no impact on the appearance and is durable over time. Does anyone have experience or recommendations on how to attach the Metod toe kicks firmly and discreetly? I would appreciate any advice!
Hello ARJEN, I’d be happy to explain a method I used for my Metod kitchen. The goal is to secure the baseboards firmly while keeping the fixings completely hidden.
- First: The original clips are okay but often not sufficient. I recommend mounting small wooden battens or timber posts behind the baseboards as a backing.
- These battens are screwed to the cabinet side panels, so they are hidden behind the baseboards.
- Then you attach the baseboards with the clips – this keeps the board firmly tensioned at the front and prevents it from wobbling.
- For extra security, you can apply small dots of mounting adhesive underneath that are not visible.
It is important to install the fixings so that no screws or brackets are visible on the front side. Make sure to align the boards precisely to achieve clean transitions. I used a combination of hidden screws and clips – this works very well and lasts for years.
If you want, I can explain the measurements and procedure in more detail.
KODAN32 schrieb:
I recommend installing small wooden battens or square timber behind the baseboards as a support.I think the approach is good, but I would like to add that this should only be recommended if the kitchen base cabinets are actually placed on a solid floor and not installed as a floating floor. Otherwise, the support battens for the baseboard could cause stress over time if the floor moves.
Furthermore, I am skeptical about using construction adhesive, as it is difficult to remove if adjustments are needed later. A good compromise could be to conceal screw connections by covering them with matching plastic caps or wood filler.
Finally, I wonder whether the original clips are really so weak that such additional measures are necessary, or if there may have been errors during installation.
Hello ARJEN, I completely understand your search. Metod baseboards are designed to be quickly assembled and disassembled, which sometimes compromises stability.
In general, there are a few basic principles that can help you:
- The baseboards should lie as flat as possible against the cabinet front – checking the levelness beforehand with a spirit level helps.
- The included mounting clips must be fully engaged, otherwise they won’t provide the necessary support.
- If the corners wobble, using small, hidden aids such as wooden wedges or plastic clips fixed with double-sided tape can help.
Additionally, a light adhesive on the back of the baseboards can ensure a secure hold over time, as long as it doesn’t leave visible marks on the front parts.
It’s important to take your time before installation and plan the individual steps carefully. I hope this helps you!
