ᐅ How do I install IKEA Metod kitchen cabinets for barrier-free accessibility?
Created on: 21 Aug 2020 09:37
Remyli
Remyli
21 Aug 2020 09:37
I am currently planning to remodel my kitchen using IKEA Metod cabinets and want to make sure to include aspects of accessible design. Specifically, I’m looking for ways to plan and install the Metod units to make them as comfortable as possible for people with limited mobility or wheelchair users. This includes easier access to work surfaces, cabinets, and storage, possibly height-adjustable components, or modifications to doors and drawers to simplify operation.
Does anyone have experience or practical tips on how to best adapt or combine the standard Metod kitchen cabinets for accessible use? I would also appreciate recommendations for additional accessories or alternative installation methods.
Thank you in advance for your feedback!
AUSTINREN
21 Aug 2020 10:42
For an accessible kitchen using IKEA Metod, I recommend starting with a design that incorporates customized work surface heights. The standard base cabinet height (approximately 60 cm depth, 60 cm height plus countertop) is often too low or impractical for wheelchair users.
Key points are:
- Open space beneath the sink and cooking area for wheelchair access (at least 70 cm width, 60 cm height)
- Height-adjustable countertops (using special frame attachments or adjustable feet)
- Drawer systems instead of deep base cabinet doors for easier access
- Handles with ergonomic design and good grip or push-to-open mechanisms
IKEA does not offer specifically accessible modules in the Metod range, but accessibility and usability can be improved with additions such as separate tall cabinets on legs and customized fronts. Accessories like internal drawers with reduced force requirements or soft-close features help with handling.
IKEA does not provide explicit assembly instructions for accessible modifications, so individualized planning based on user measurements is highly recommended.
koduga
21 Aug 2020 11:13
I can fully understand how important accessible kitchen design is. I tried something similar a while ago because my mother uses a wheelchair, and we wanted to make the kitchen as user-friendly as possible.
One thing we learned: it’s worth keeping the cabinets in the Metod framework fairly flexible and placing a lot of emphasis on the height and the handles. Handles, in particular, can be a major obstacle if they are too delicate or narrow.
If you like, I can also share from my own experience that with a little effort, you can extend the countertop and create height recesses so that it’s easier to approach under the work surface with a wheelchair. It does require some manual work, but it’s really worthwhile for everyday use.
Do you already have specific measurements or requirements regarding the mobility of the future users?
PAR63
21 Aug 2020 14:58
Generally, I recommend approaching this systematically, so here is a short tutorial on how to adapt IKEA Metod kitchen units for accessible use:
- Step 1: Assess needs. Identify the main barriers (e.g., wheelchair, walking aid, limited grip strength).
- Step 2: Measure the users’ body dimensions, especially sitting height in a wheelchair, arm length, and reach.
- Step 3: Plan cabinet height. Adjust the standard height: base cabinets at around 75-85 cm (30-33 inches) high, but with clearance underneath of 67-70 cm (26-28 inches) for wheelchair access.
- Step 4: Choose fronts and handles, e.g., T-handles or push-to-open mechanisms, to avoid the need to grip handles tightly.
- Step 5: Install interior drawers and pull-outs with soft-close technology — this significantly eases operation.
- Step 6: When installing the countertop, set it at the appropriate distance to allow legs to fit comfortably underneath.
Typical mistakes include neglecting the clearance under the countertop or using door fronts on base cabinets instead of drawers, since doors can be harder to open for people with limited mobility.
If you like, I can also provide details on specific IKEA parts and modifications.
Remyli
22 Aug 2020 08:29
AUSTINREN schrieb:
Open space under the sink or cooking area for wheelchair access (at least 70 cm wide, 60 cm high) (28 inches wide, 24 inches high)
Thanks for the tip, the open space under the sink and cooktop sounds very important. I was wondering if you should use special sink modules from IKEA for this, or if they are generally designed in a way that leaves this space open anyway. Are there any recommendations on whether it’s better to customize yourself or to look for specific models?
That makes sense. I’ve been thinking about also using individual tall cabinets, which can then be adjusted higher or lower as needed if drawers become less accessible.
koduga schrieb:
Do you already have exact measurements or requirements regarding the mobility of the future users?
Yes, the person uses a power wheelchair with a seat height of about 50 cm (20 inches), and a reach of around 85 cm (33 inches). These are important values I want to base the design on.
Does anyone have tips on how to make IKEA Metod fronts easier to operate? For example, swapping handles for different ones or adding other aids?
Wesley
22 Aug 2020 09:04
Remyli schrieb:
Does anyone have tips on how to make the Ikea Metod cabinet fronts easier to use?
Hey, there are actually a few options! You could go for handles that are larger, more grippable, and ergonomic. IKEA offers some models with bar handles, which are much easier to grip than flat ones.
Or you could try push-to-open mechanisms, so you don’t even need to pull. This can be especially useful if hand strength is limited.
A little tip: The standard Metod fronts can also be replaced by other manufacturers’ fronts with matching dimensions, where you might find ergonomically better handles or even soft-touch finishes. Some DIY work will be required, though!
And hey, don’t be afraid of a bit of hassle during renovation – if the kitchen ends up fair and user-friendly, it’s definitely worth it.
