ᐅ Functionally planning Ikea Metod kitchen cabinets for limited space conditions
Created on: 28 Jul 2018 14:37
Fifalen
Hello everyone, I’m currently planning my small kitchen with Ikea Metod kitchen units and am facing the challenge of making the most of the limited space available. The kitchen is only 6 square meters (65 square feet), and the layout is somewhat awkward with a slight alcove on one side, which means the usual rectangular designs don’t fit easily.
My question to the community is: How do you plan your Ikea Metod kitchen units in tight spaces to keep things functional while still having enough storage and work surface? I’m particularly interested in which types of cabinets, inserts, or combinations you use to make efficient use of the space without making the kitchen feel overcrowded or impractical.
I would also appreciate any tips on storage solutions that work especially well with the Metod series. Thanks in advance!
I agree with enrique7 on some points. In smaller spaces, drawers that open into walkways can quickly become a problem. A well-planned kitchen layout is crucial. Therefore, I recommend planning for a galley kitchen when the floor plan allows, rather than U-shaped or L-shaped layouts with large corner cabinets that limit movement. Regarding Ikea Metod, I find it important to take advantage of its flexibility—for example, using open shelving units instead of continuous tall cabinets. This helps create a sense of visual spaciousness. Another tip: avoid unnecessarily deep base cabinets, as they consume space and can be counterproductive in narrow kitchens.
enrique7 schrieb:
Maybe narrower cabinet widths and so-called "blind cabinets" with clever storage solutions could be an alternative.That sounds very interesting – could you please explain in more detail what you mean by "blind cabinets" and how they can be practically used with Ikea Metod? I understand that space is limited and standard widths sometimes don’t fit, but I haven’t quite grasped how these elements can create more storage. Also, are there any experiences on how to best balance clearances for movement and maximizing storage? For example, I have only about 90cm (35 inches) of walkway width in the middle of my kitchen, which gets very tight when large drawers are open.
Fifalen schrieb:
Are there any experiences on how to best balance measures for freedom of movement and storage use?Finding the right balance between storage space and freedom of movement is a common challenge in small kitchens. With a walkway width of 90 cm (35 inches), freedom of movement and ergonomic workflow are only reliably achieved if drawer extensions are limited to a depth of 50-55 cm (20-22 inches) at most, preventing the fronts from extending beyond the middle of the walkway. Ikea Metod also offers base and wall cabinets that are 40 cm (16 inches) deep. These smaller dimensions help maintain better flow, even though the overall storage capacity is somewhat reduced.
Regarding blind cabinets: these are narrow cabinets usually installed in niches or alongside appliances, often equipped with internal shelves or pull-out elements. Visually, they blend in next to larger cabinets and are used to close narrow, otherwise unused gaps, creating the impression of a continuous front. With Metod, such narrow cabinets are easy to plan in widths of approximately 10, 15, or 20 cm (4, 6, or 8 inches).
Romin schrieb:
The most important thing is to use your upper cabinets effectively and opt for drawer cabinets, as they offer a much better overview and easier access than simple cupboard doors.I find this opinion one-sided – whether drawers or doors are better depends heavily on individual needs and space conditions. In extremely small kitchens, drawers can actually be limiting because they require a lot of space to open. Upper cabinets with simple doors also have the advantage of appearing less bulky and not visually restricting the room as much. It can also be beneficial to consider wall-mounted shelves or open shelving, as this creates a sense of openness.
Additionally, I have found that less is often more – a minimalist design with reduced furnishings can visually enlarge small kitchens and improve functionality.
LIELCHEN schrieb:
I have also found that, in general, less is often more – a minimalist design with reduced furnishings can visually enlarge small kitchens and improve functionality.Good point! However, minimalist doesn’t necessarily mean less storage or functionality. The goal should be to furnish the space only with necessary furniture and thoughtfully designed storage. With Metod, this works excellently thanks to clearly defined organizational systems. Small kitchens also benefit from consistent color schemes and handleless fronts, which make everything look calmer and more spacious. Therefore, I would recommend planning storage so that every centimeter (inch) is used efficiently, while keeping surfaces clearly organized. That’s how Metod works great in small spaces!
