ᐅ How can I safely transport IKEA Metod kitchen cabinets during a move?
Created on: 15 Aug 2023 08:37
Henny
Henny
15 Aug 2023 08:37
I am planning to move next month and intend to take my IKEA Metod kitchen units with me. Since these are fairly sturdy but quite bulky pieces, I want to make sure they don’t get damaged during transport.
My question is: How can I safely transport IKEA Metod kitchen units during a move?
What preparations are recommended to avoid scratches, breakage, or deformations? Are there any specific techniques or packing materials that have proven to be especially effective?
I would appreciate any tips on disassembly, padding, and loading, especially since I experienced in my last move that kitchen units can easily suffer damage if they’re not properly secured.
farGlen
15 Aug 2023 08:42
Hi, the most important thing is to disassemble the furniture. Pack the bases, doors, and shelves separately. Use thick blankets or bubble wrap for cushioning. The large pieces are best transported standing up and well secured in the van.
kaubi
15 Aug 2023 09:11
Hello Henny,
for the safe transport of IKEA Metod kitchen cabinets, I recommend thorough preparation in several steps:
- First, it is advisable to completely disassemble the kitchen units as much as possible. Be sure to remove the fronts (doors and drawers) and pack them separately and securely, as they are particularly fragile.
- Collect screws, dowels, and all small parts in clearly labeled small bags to ensure nothing is missing later and the reassembly goes smoothly.
- Use bubble wrap or moving blankets for the individual units. Corner units especially need thick padding to absorb impacts.
- When stacking the furniture parts in the transport vehicle, it is generally best to store them upright to avoid excessive load from below.
- If you have to pass through basements or stairways, plan sufficient carrying and securing breaks to prevent damage.
Also, paying attention to temperature and humidity during transport can help, as wood and particle boards can be sensitive to moisture. Did you handle your last kitchen move electrically or manually? That could help me assess which challenges might be most relevant for you.
Henny
15 Aug 2023 09:28
kaubi schrieb:
Paying attention to temperature and humidity during transport can also help, as wood and particleboard can be quite sensitive to moisture. Did you handle your last kitchen move electrically or manually? That could help me assess which challenges might be most relevant for you.
Thank you for the detailed response!
Last time, I handled the kitchen furniture quite roughly, just wrapped in a few blankets, no special protective film. It wasn’t disassembled properly since it only involved a few cabinets and not the entire kitchen. Honestly, I hadn’t thought much about temperature or humidity, but that sounds important.
My new plan is definitely to dismantle everything and pack it well. Do you have any recommendations for especially sturdy packing materials? Or experience with whether certain types of adhesive tape might damage the surfaces of the furniture?
Paxton38
15 Aug 2023 10:03
Regarding packaging materials: bubble wrap is the standard choice because it is flexible and provides cushioning. Additionally, you should use sturdy furniture blankets to protect surfaces and prevent scratches.
As for tape, I recommend using painter’s tape or special furniture tape with low adhesive strength to avoid direct damage to surfaces. Regular packing tape can sometimes strip coatings, especially if it gets warm from sunlight.
Disassembling the modules and removing the drawers is, in my opinion, essential for safe transport. This way, the parts can be packed more compactly and securely.
theo63
15 Aug 2023 11:14
kaubi schrieb:
- When stacking furniture parts in the transport vehicle, it is generally advisable to store them upright to avoid excessive load from underneath.
I see this a bit differently. Storing items upright makes sense to place the weight on the frame, but especially with Metod cabinets, which often have large, thin particleboard side panels, there is a risk of damage if the load is uneven.
My recommendation:
- Store parts so that no sharp edges or heavy weights press directly on the panels
- Pack as securely as possible to prevent movement
- Lay items crosswise with sufficient cushioning to avoid warping
Otherwise, the supposed advantage of storing upright can quickly turn into breakage, especially if the load shifts during transport.
