ᐅ How do I install Ikea Metod cabinets with sliding doors?
Created on: 4 May 2019 08:37
agilulfg42
agilulfg42
4 May 2019 08:37
I want to install several Ikea Metod cabinets with sliding doors in my new kitchen and am looking for a detailed guide. I am particularly interested in the following points:
- How exactly are the sliding doors attached to the Metod system?
- What should I pay attention to when installing the running rails to ensure smooth operation?
- Are there any special tools or tips that make the work easier?
- How do I properly adjust the doors in height and depth?
I am aware that Ikea provides instructions, but they seem a bit superficial to me. Who has practical experience or can offer a step-by-step explanation? Thanks in advance!
Guyju
4 May 2019 09:46
Hello agilulfg42,
your question is very well structured – I’m happy to provide an overview for assembling the Metod cabinets with sliding doors:
- Preparation: Unpack all components and sort them carefully, especially the sliding door tracks and rollers.
- Installing the track profiles: These are screwed to the top and bottom of the cabinet frame. Make sure the tracks are perfectly parallel – this is crucial for the smooth operation of the doors.
- Attaching the sliding doors: The door rollers are hooked into the tracks. It helps to slightly lift and angle the doors when inserting them.
- Adjustment: Ikea offers small adjustment screws for precise height and depth settings of the doors. Use a small Allen key and adjust the doors until they close properly and move smoothly.
- Tools: Besides a cordless drill and a Phillips screwdriver, I recommend a spirit level and a tape measure. An offset screwdriver can be useful for tight spots.
Tip: It’s best to work with a partner so you can more easily align the doors and cabinet frame.
I hope this helps you for now!
BERONAR
4 May 2019 11:03
Guyju schrieb:
Make sure the profiles are perfectly parallel – this is crucial for the smooth operation of the doors.
I completely agree – but I think many people completely overlook the top part. Only when all profiles are installed perfectly straight and flush will you truly enjoy the sliding doors later on.
Why does everything always have to be so fiddly and frustrating? Ikea claims it’s simple – but don’t be fooled by that. Especially with Metod sliding doors, you need a delicate touch, patience, and above all, precise workmanship. Anyone who rushes here will be annoyed weeks later by squeaking doors or uneven tracks.
And one more slightly provocative point: I find Ikea sliding doors are often more of a compromise than a genuine comfort solution. But if installed carefully, they work reasonably well.
Still, respect to everyone who keeps their patience!
Timofa
4 May 2019 12:16
So, I don’t find assembling the Metod cabinets with sliding doors that complicated! 😄 If you take a systematic approach, it can even be fun.
Here’s a little tip from me: If you first hang the doors in the tracks without fastening the screws, you can freely try out different adjustments to see what fits best. Then tighten the screws securely, and everything sits perfectly.
One more thing: The screws supplied by Ikea didn’t always hold optimally for me. I therefore used a set of small stainless steel screws – these are easier to adjust and won’t rust either.
Of course, it takes a bit of finesse, but in the end, the result is really satisfying!
agilulfg42
5 May 2019 07:58
Guyju schrieb:
Tip: It’s best to work in pairs, so doors and the cabinet body can be aligned more easily.
That’s an important tip, thanks! I initially planned to do it alone since I don’t have a helper – that could make things a lot more difficult.
One more question about adjustment: How exactly do I change the depth setting on the sliding doors? Are the adjustment screws located inside the frame or on the rollers? Is the adjustment limited to Ikea tools only, or can a regular hex key (Allen wrench) be used as well?
Also, is there a specific order to adjust height first and then depth, or vice versa?
I’m grateful for any advice!
Guyju
5 May 2019 09:23
agilulfg42 schrieb:
How exactly do I adjust the depth setting on the sliding doors? Are the adjustment screws inside the frame or on the rollers?
From my experience, you usually find the adjustment screws directly on the rollers that run inside the tracks. You can adjust the depth there using a small hex key – yes, a standard Allen wrench works fine.
agilulfg42 schrieb:
Is there a sequence for adjusting height first and then depth, or vice versa?
I recommend adjusting the height first—that is, aligning the door vertically so it sits straight within the frame. After that, you can adjust the depth to ensure the door closes flush and operates smoothly. This sequence makes the installation much easier.
One more tip: support or slightly lift the door while adjusting to make it easier to turn the screws.
