ᐅ How do I assemble IKEA Metod cabinets with soft-close hinges and adjustable shelves?
Created on: 11 Feb 2019 08:43
FarroHello everyone! I am currently planning to build kitchen and storage cabinets using the Ikea Metod system and want to equip them with soft-close hinges as well as adjustable, variable shelves. My question is: What is the best way to assemble these cabinets to ensure the soft-close function works properly and the shelves remain stable and easy to adjust? Do you have any proven techniques or tips for the assembly process, for example regarding screws, drilling, hinge alignment, or other potential pitfalls? I am especially interested in whether additional components are needed to optimize the adjustability of the shelves and how the soft-close mechanism should be installed. I would greatly appreciate a detailed step-by-step explanation!
Great question, Farro! 😊 A few months ago, I assembled several Metod cabinets with soft-close hinges and adjustable shelves, and I can definitely encourage you: it’s easier than it looks! The key is to mount the hinges roughly first and then use the adjustment screws to properly align the doors. The soft-close mechanism is usually located behind the hinges—you can hear it click into place with a gentle push. When adjusting the shelves, be sure to place the supplied brackets exactly into the pre-drilled holes; these are designed to hold the boards securely while still allowing height adjustment. I’d be happy if you keep going and share your experiences! If you want, I can also provide more tips on tools and screws.
Hello Farro, I would like to build on your well-written post and provide you with a detailed guide. Step 1: Before assembly, check all parts—especially the hinges and shelf supports—for completeness and any transport damage. Step 2: Start with the carcass, making sure the side panels are perfectly squared at right angles. Step 3: Attach the soft-close hinges to the doors and temporarily fit them onto the carcass. Each hinge has three adjustment screws: the first adjusts the door up and down, the second moves it forward and backward, and the third adjusts it sideways. Step 4: Adjust the shelves—by placing the supports into the correct holes, the shelves will remain stable without wobbling. Step 5: If needed, fine-tune the door alignment until the soft-close mechanism closes smoothly. Avoid forcing the doors out of alignment too much, as this can affect the system’s performance. I also recommend tightening the screws with a cordless drill equipped with a torque limiter to prevent damage. Good luck!
I can understand that assembling Metod cabinets with soft-close features and adjustable shelves can sometimes feel intimidating, especially when you want to make the most of their functionality. Personally, I initially had doubts about whether I could properly adjust the doors and ensure the shelves would hold securely. My experience is: take your time and try to tighten every screw carefully. There is one small catch: if the hinges are not fitted correctly or a side panel isn’t perfectly aligned, the soft-close mechanism won’t work properly. That can be frustrating—but with a bit of trial and error, it can be fixed. I wish you lots of patience and encourage you to keep at it! If it gets too tricky, feel free to reach out again.
Yes, Farro! I love the Metod cabinets with soft-close! 🤩 The gentle closing is definitely worth every penny. Important: Align the hinges properly; usually, the small adjustment options provided by Ikea help to make sure the doors fit perfectly on the front. Also, be sure not to overload the shelves too much. The brackets hold well, but excessive weight can make adjustments more difficult. Tip: If you want everything to operate smoothly, try applying a few drops of silicone oil to the hinge joints; it makes the soft-close function even more pleasant.
