ᐅ How do I install IKEA Metod cabinets in small kitchen layouts?
Created on: 16 Nov 2024 08:37
gipeblaHello everyone, I am currently planning to remodel my small kitchen and would like to use IKEA Metod cabinets. However, I am struggling with the relatively limited space in small kitchens.
My question is: What is the best way to install IKEA Metod cabinets in small kitchen layouts to optimize the use of space while still providing enough storage and keeping the kitchen from feeling too cramped?
I am especially interested in tips for combining cabinet modules, practical arrangements (corners, drawers, tall cabinets), and any helpful tools or accessories to efficiently set up the cabinets in tight spaces.
Perhaps there are also tricks to keep in mind during installation to ensure everything is stable while keeping the small spaces feeling open.
I would appreciate any concrete experience or recommendations!
Hello gipebla,
for small kitchens, a clear and systematic plan is recommended to make the best use of the available space with IKEA Metod cabinets. Here are some practical tips:
- Prefer upper wall cabinets and tall cabinets that reach up to the ceiling to utilize vertical space.
- Corner cabinets with rotating internal pull-outs (e.g., Le Mans carousel) provide a lot of storage despite a small footprint.
- For countertops, use a depth of 60 cm (24 inches); in very tight kitchens, a shallower depth can also be useful to save space.
- Avoid too many different cabinet widths to ensure the modules fit together and to prevent unnecessary gaps.
- Use internal pull-outs and drawer inserts to store small items efficiently.
During installation, it is advisable to mount the tall cabinets first, then the base cabinets, and finally the wall cabinets to ensure stability. In small kitchens, pay special attention to securely fixing the cabinets to the wall.
With precise planning and solid installation steps, you will achieve a functional small kitchen with IKEA Metod.
Hey gipebla, that sounds like an exciting project! You’ll see, with IKEA’s Metod cabinets you can really enhance even small kitchens.
An important tip from me: take your time with detailed planning and compare your kitchen measurements to the cabinet sizes. Especially in tight kitchens, less is often more – go for slim cabinets and practical drawers.
Try using wall cabinets that reach up to the ceiling; this provides a lot of extra storage without making the space feel cramped. 🙂
Also, if you assemble the cabinets with friends, everything goes much faster and it’s actually a lot of fun! I’ve installed the Metod cabinets myself three times and I can only say: keep at it, the result is really worth it! Good luck!
KAULIS schrieb:
Corner cabinets with rotating pull-outs (e.g., Le Mans carousel) offer a lot of storage space despite their small footprint.I’d like to add here – especially in small kitchens, planning the corners is essential.
Here is a brief step-by-step guide on how I assembled my IKEA Metod cabinets in a very tight kitchen:
- Step 1: Measure the room and dimensions precisely, including the distance to door openings and windows.
- Step 2: Choose the cabinet types – as mentioned, Le Mans carousels are invaluable for corners.
- Step 3: Plan tall cabinets where they don’t obstruct the flow of movement.
- Step 4: Carefully level the base cabinets, as small unevenness is quickly noticeable in compact kitchens.
- Step 5: I recommend not fixing the cabinets directly to the floor but using a plinth system – this makes it easier to access wiring and water pipes.
Common mistakes:
- Using too many different cabinet widths, which later causes gaps or holes in the installation.
- Cabinet doors that block each other.
If you like, I can also create a simple checklist for your planning that will help you during the assembly.
Davidleo schrieb:
Also: Working together with friends during assembly makes everything much faster and even more fun!I would agree with that immediately! 😄 Also, if you play some music, the assembly will probably go even smoother.
I would also recommend not to skimp on cabinets – better to include a few more modules for storage, because especially in small kitchens, clever organization is key. Use wall cabinets to keep the floor area clear, which makes the space feel larger.
And don’t be afraid of the screwdriver! With a little patience and occasionally referring back to the instructions, you’ll achieve a great result!
