ᐅ How can you protect Billy from moisture damage?
Created on: 18 Oct 2020 08:12
glajulius
I would like to discuss a topic that is very important to me for my project: How can you protect Billy from moisture damage?
Billy is very popular as a shelving unit, but especially in more humid environments or rooms with high humidity, I am concerned that it might get damaged. I have heard of various methods, such as special water repellents, avoiding direct contact with water, or using moisture absorbers.
I am particularly interested in which measures have proven to be truly effective in everyday use, both preventive and for rescue when moisture is already visible. I look forward to your well-founded tips, experiences, and perhaps advice on common mistakes to avoid.
giabau
19 Oct 2020 07:49
glajulius schrieb:
What is the maximum allowed humidity level in living spaces?
For reference: Ideal daily average values are between 40-60% relative humidity. Important: Measure not only in the room air but also behind or under furniture, as moisture can accumulate there.
One more tip: Air the rooms by fully opening windows several times a day. This ensures quick air exchange and reduces risks.
Friedrich
19 Oct 2020 08:32
I see that the topic of moisture protection with Billy is complex.
One should not underestimate the psychological aspect: Those who fear damage sometimes tend to place furniture in unsuitable rooms or too close to walls.
Good air circulation and the right location not only protect against damage but also provide peace of mind.
Thanks to everyone for the valuable advice; I hope this helps many here and prevents any further damage.
blapau
19 Oct 2020 10:50
Just a quick clarification to clear up a misunderstanding: not all paint coatings provide sufficient protection against moisture, especially if they are not specifically water-repellent.
Standard paints are often only splash-proof and not permanently moisture-resistant. That is why wood sealants or transparent moisture barriers are better suited when using Billy in vulnerable areas.
For effective sealing, products that are explicitly designed to protect wood in damp environments should be preferred.
pikin
20 Oct 2020 11:14
blapau schrieb:
Not all coatings provide sufficient protection against moisture
Exactly. That’s why careful surface preparation before applying a coating is crucial. A poorly prepared surface absorbs moisture more quickly.
Polishing, sanding, and cleaning before treatment extend the protective effect.
Another tip: Wood oils with water-repellent additives can be a good alternative to coatings, as they keep the wood breathable.
