I would like to discuss a topic that is very important to me for my project: How can you protect Billy from moisture damage?
Billy is very popular as a shelving unit, but especially in more humid environments or rooms with high humidity, I am concerned that it might get damaged. I have heard of various methods, such as special water repellents, avoiding direct contact with water, or using moisture absorbers.
I am particularly interested in which measures have proven to be truly effective in everyday use, both preventive and for rescue when moisture is already visible. I look forward to your well-founded tips, experiences, and perhaps advice on common mistakes to avoid.
glajulius18 Oct 2020 13:02giabau schrieb:
Prevention through site selection + protection against splash water + humidity regulation in the room are effective.Thank you for the detailed explanation!
One question: Are there any specific materials you would recommend? I’ve heard of waterproof membranes or special felts, but I’m not sure if they are really better than simple rubber pads.
Also – what is the maximum humidity level allowed in living spaces to prevent damage to Billy? I often have around 50-60% relative humidity, which might already be risky, right?
glajulius schrieb:
Are there any specific materials you would recommend?Yes, I recommend flexible sealing mats made of rubber or EVA foam, as they are water-resistant and also distribute pressure evenly. Felt is comfortable, but it absorbs moisture and can retain it, which is counterproductive.
Regarding indoor humidity: levels above 60% over a prolonged period can cause issues, especially if there is poor air circulation. Around 50% is usually not problematic, provided there is good ventilation.
In addition to the measures already mentioned, I would like to add the idea of technical moisture control.
For example, using a dehumidifier in living spaces with high humidity is a practical option.
Additionally, hygroscopic materials such as silica gel can be placed in bowls or boxes to locally reduce humidity.
It is important to regularly check for condensation on walls or behind furniture, as moisture often causes damage unnoticed in these areas.
janfo schrieb:
Do not place it directly against cold exterior walls under any circumstances.This is a very important recommendation. Rooms with insufficient insulation can be especially problematic in this regard.
Additionally, it helps not to push the shelf tightly into corners against the walls to allow air circulation.
Using vapor-permeable materials behind or beneath the Billy shelf also reduces moisture buildup.
