ᐅ Installing a Billy Bookcase in a Basement with High Moisture – Tips and Tricks
Created on: 17 Feb 2020 08:23
PINMU6Hello everyone, I want to install a Billy shelf in my basement, but I have the problem that the humidity there is quite high, especially during the cold season. Of course, I want the shelf to be stable and to remain undamaged in the long term. Has anyone had experience installing Billy shelves or similar furniture under such conditions? How can I carry out the installation so that the moisture affects the shelf as little as possible? Are there special materials or tricks to protect the wood or maintain stability? I would appreciate detailed tips since I mainly want to use the shelf for storing books without moisture damage. Thanks in advance!
For reference: First, you should accurately measure the humidity in the basement; ideal levels are below 60%. If these levels are consistently exceeded, I recommend using hygroscopic membranes or special vapor retarders below and behind the shelving unit.
Here is a brief guide:
1. Clean and dry the substrate.
2. Protect it with a PE (polyethylene) sheet or a special vapor retarder membrane.
3. Install spacers made of plastic or aluminum between the shelving unit and the floor.
4. Treat the shelving components with a wood preservative coating that protects against moisture.
5. Regularly monitor the indoor humidity.
A common mistake is placing the shelving directly against exterior walls or damp surfaces—ensure proper air circulation in these cases!
I had a similar problem and used silicone rubber beads under each leg, which keeps the wood completely off the floor and allows air circulation. Additionally, I treated the shelves with a moisture-resistant oil. That works wonders, especially if the shelf is for books – they need a place that is as dry as possible.
If the basement is very damp, an electric dehumidifier could also help to prevent long-term damage.
I would like to add a brief critical comment here. Simply treating wood with clear varnish or oils does not provide adequate protection if the basement humidity remains consistently high (>70%). This also applies to spacer strips.
This might work in moderately dry basements, but in genuinely damp rooms, I recommend alternatives such as metal shelving or specialized furniture made of plastic. Bookshelves made of MDF (like the Billy shelf) are very susceptible to mold or swelling.
What are the long-term measured humidity levels in your space? Do you have a ventilation strategy or mechanical dehumidification planned?
Josan schrieb:
additionally, I treated the shelves with a moisture-resistant oil.
Thank you for the tips so far! The humidity in winter is around 65-70%. A mechanical dehumidifier is currently not planned (it uses a lot of electricity and is expensive). I can only ventilate sporadically because the basement is underground and there is little air circulation. So far, the plan was to place the shelf on spacers and treat the shelves once with transparent wood protective oil. Would it be better to avoid wooden shelves altogether? I was hoping the furniture would last for several years after treatment.
