ᐅ How can IKEA PLATSA be upcycled for DIY projects?
Created on: 13 Oct 2024 09:32
flosi
flosi
13 Oct 2024 09:32
I am currently planning a DIY project using the IKEA Platsa series as a base and am looking for creative ideas and tips on how to effectively upcycle PLATSA furniture. My main focus is on customizing the modular units individually and enhancing their appearance without completely disassembling them or changing the basic structure. I am also interested in sustainable and practical upcycling methods that involve altering existing surfaces, adding new functions, or making the furniture more durable for long-term use.
Does anyone have experience upgrading PLATSA as a framework for more complex DIY furniture? For example, by installing LED lighting, using creative combinations of colors or materials, or repurposing it for different areas of the home? Tips on tools, materials used, or potential pitfalls to watch out for are also very welcome.
I would also like to know if there are special techniques to make the characteristic thin MDF parts in PLATSA more stable and durable, especially when planning to paint or heavily modify them.
I’m looking forward to your suggestions, exchanges, and all kinds of tips—the more detailed, the better!
Thanks in advance.
Filippo
13 Oct 2024 11:07
Hello flosi,
Very interesting question! IKEA PLATSA is indeed attractive for upcycling due to its modular design and relatively thin panels, but it also presents some challenges—especially when it comes to stabilizing and finishing.
First of all, I would recommend fully disassembling the individual modules before starting your work, if the project allows. This makes precise work on surfaces and interior fittings much easier. For surface treatment, such as painting, two components are particularly important: a thorough primer and the choice of the right type of paint. MDF absorbs heavily, so be sure to use a good wood primer to prevent the paint from running or being applied unevenly. For durability, acrylic paints or two-component (2K) paint systems that cure hard are suitable.
When it comes to stabilization, attaching thin plywood or multiplex panels (for example, 3 mm (1/8 inch) thick) to the back of the side panels is a proven method. This increases resistance against warping and generally makes the piece of furniture more robust. Ethylene vinyl acetate (EVA) pads or small battens as spacers also help improve the clamping pressure of the joints.
A popular LED integration method is, for example, mounting narrow LED strips (typically 12V, warm white) at the top area of the carcasses, either by screwing them on or fixing them with double-sided tape. Since PLATSA modules have many open backs, you can easily hide the wiring inside. To avoid permanent damage from cables, I also recommend planning cable channels with recesses—using a router with the appropriate bit profile works best for this.
Regarding material combinations: applying decorative films or real veneer on the fronts can achieve very individual looks. Here, you should make sure the bonding surface is absolutely clean and free of grease—preparing it with fine sandpaper improves adhesion.
As tools, I recommend: router for custom recesses, an accurate measuring tape, sandpaper in different grits, a spray gun or at least a high-quality paint roller, and of course a dust protection mask.
Lastly, it would be helpful to know in which room the furniture will be placed (living room, kitchen, bathroom?), as this can affect the choice of materials and the type of sealing used.
I’m also happy to share some of my upcycling projects with PLATSA if you are interested.
What are the details of your planned project?
gasidney
13 Oct 2024 12:45
Hello flosi,
for quick and easy upcycling ideas for PLATSA, you could try the following:
- Cover the fronts with self-adhesive foil or contact paper in wood or stone finish.
- Replace the handles with stylish metal or leather ones for a fresh look.
- Install LED strips inside, especially in shelves or cabinet areas.
- Attach steel tube frames or wooden legs at the bottom to use the furniture as a sideboard or bench.
Is this a sufficient rough assessment? More details can be provided later if needed.
Nabla64
14 Oct 2024 08:21
Hello flosi,
I would like to add my experience with a structured upcycling workflow for IKEA PLATSA to answer your questions about surface treatment and stabilization in more detail.
1. Preparation:
- Completely disassemble the furniture to access all surfaces.
- Slightly bevel the edges using fine sandpaper (240 grit) to ensure better adhesion of the primer.
2. Stabilization:
- The thin side panels of the PLATSA system are usually made of MDF or particleboard with a foil coating. To make them more durable, it is advisable to glue an additional backing panel of 3-4 mm (1/8–5/32 inch) plywood. You can attach this to the back with wood glue and additionally secure it with small screws.
- Caution: When screwing, avoid directions where the material may split. Pre-drilling is essential here.
3. Surface finishing:
- After sufficient drying time for the adhesives and treatment products, apply a wood primer specifically designed for MDF or particleboard.
- Then apply several thin and even coats of water-based acrylic paint, sanding lightly with fine sandpaper between each coat.
- Alternative options: a durable wax layer or oil treatment for open-pored surfaces.
4. LED integration:
- PLATSA modules often have gaps at the back, so it is usually sufficient to discreetly route LED cables along the inside edges and secure them with cable clips.
- RGB LED strips with remote control are flexible and relatively easy to install.
5. Tips to avoid mistakes:
- Do not apply paint too thickly to avoid unsightly drips.
- Do not pull cables too tight to prevent stressing the connections.
- Always pre-drill when drilling and screwing to avoid material breakage.
Finally, a quote from your initial post that I find particularly relevant:
flosi schrieb:
Mich würde auch interessieren, ob es spezielle Techniken gibt, um die charakteristischen dünnen MDF-Teile bei PLATSA stabiler und langlebiger zu machen
I hope this overview helps you! If you like, I can also provide specific product recommendations.
Good luck with your project!
