ᐅ How can Ikea Pax wardrobes be cut or shortened flexibly?
Created on: 8 Jan 2020 10:23
sankin30
sankin30
8 Jan 2020 10:23
I am currently planning a custom Pax shelving unit from Ikea. Since the standard heights and widths do not fit my space exactly, I am looking for ways to cut the shelves flexibly and, above all, precisely. My questions are:
- What is the best way to adjust the IKEA Pax system if the unit needs to be shortened in height or depth?
- Which tools and techniques are recommended to maintain stability and appearance despite the modifications?
- Are there specific parts (e.g., side panels or back panels) that can be easily shortened or that should rather be replaced?
- What potential pitfalls should be considered when modifying the components?
I want to avoid the shelf being wobbly or looking unprofessional afterwards. If anyone has experience or tips and tricks on how to cut Ikea Pax units flexibly, I would really appreciate it. Thanks in advance!
REOHEINRIC
8 Jan 2020 11:05
Basically, Ikea Pax units are designed for modular use but are not intended for shortening the side panels or shelves. For flexible trimming, I recommend the following approach:
- The side panels and shelves are made of coated particleboard. Sharp, fine-toothed saws (e.g., a circular saw with a guide rail or a jigsaw with a fine blade) should be used to achieve clean cut edges.
- It is important to protect all edges with masking tape (e.g., painter’s tape) before cutting to prevent the surface from chipping.
- After trimming, the cut edges should be smoothed with sandpaper (grit 220 or finer). Applied edge banding or acrylic strips provide additional stability and protect against moisture.
- Back panels are usually made of thin hardboard material. These are somewhat easier to trim but help stabilize the frame. Alternatively, the back panel can be replaced with a suitably cut piece of particleboard.
- When shortening the height, be sure to check the functionality of hinges and drawers, as adjustments may be necessary.
- Changing the depth is difficult because the prefabricated unit parts are often precisely coordinated.
Such modifications require precise work and some craftsmanship skills. Otherwise, I recommend consulting a professional workshop or a carpenter.
pinJustin
8 Jan 2020 12:34
Side panels for Ikea PAX can be carefully shortened using a good jigsaw or handheld circular saw. Important: Protect the cutting line with tape beforehand. Afterwards, sand and seal the edges. Back panels are thin and easier to work with. When it comes to the height, you need to check if the door hinges still fit.
dunitan
9 Jan 2020 08:57
pinJustin schrieb:
You can carefully shorten the side panels of Ikea PAX units using a good jigsaw or circular saw.
That’s a good starting point. Additionally, I want to emphasize that it’s important not only to focus on the cutting technique but also to keep the following points in mind:
- Take plenty of time for precise measurements and markings. A misplaced cut line can be costly.
- Keep in mind that the PAX components are not made of solid wood but of veneered panels; therefore, the surface is delicate.
- After cutting, consider finishing the cut edges with suitable cover strips or self-adhesive edge banding to achieve a clean appearance.
- Regarding height: Sometimes it’s better to get shorter hinges or adjust the hinges afterward if the shortening affects their fit.
- If you want to reduce the depth: Although the side panels can be trimmed, the feet and shelves may cause issues since they are designed for the original depth. In this case, it’s advisable to cut suitable shelves separately or have them custom made.
In summary, craftsmanship and patience are essential. If you have little experience with these kinds of tasks, consider at least having the panels cut by a professional.
rebufar
9 Jan 2020 11:42
dunitan schrieb:
If you want to reduce the depth: The side panels can be trimmed, but the feet and shelves might cause problems since they are designed for the original depth.
That doesn’t fully cover it. In my opinion, Ikea is selling a lot of semi-finished components that are not made for cutting at all. Sure, you can try with some basic DIY skills – but in the long run, it doesn’t make sense because you will never get a stable construction.
“Flexible trimming” usually means “makeshift work,” and when you move or need to attach a load to the wall, such temporary fixes will definitely fail.
I believe that if you want something reliable and stable, you either have to build it completely yourself or at least accept the PAX system’s installation guidelines and adjust your measurements accordingly instead of cutting into the prefabricated parts. Some improvisation is fine, but in my view, it’s not a good idea with PAX.
lejesin
10 Jan 2020 09:13
In summary, flexible cutting of Ikea PAX wardrobes is technically possible but comes with significant limitations. The key points are:
- Side panels and shelves can be cut using appropriate power tools but require precise and careful work to avoid damage.
- The PAX system’s connection hardware (e.g., cam connectors, hinges) is designed for specific dimensions, which can cause functional issues when parts are shortened.
- The stability of the wardrobe largely depends on the back panel and maintaining original dimensions. Cutting can compromise this and often requires additional reinforcement.
- Alternatively, individual components can be replaced with new, properly sized panels, though this requires skilled craftsmanship.
My advice to the thread starter: Consider whether your space could be better optimized by using several smaller standard PAX units instead of cutting parts. If cutting is unavoidable, it should be carefully planned and ideally done by someone with experience.
