ᐅ How can the Ikea Pax wardrobe system be adapted for use as a shoe cabinet?
Created on: 2 Apr 2017 08:13
EMILY
I am currently planning to convert my existing Ikea Pax wardrobe into a shoe cabinet and would like to hear your recommendations and tips. Specifically: How can the Pax wardrobe (considering dimensions, interior layout, load capacity, and materials) be best adapted as a shoe storage unit?
It is important to me not only to hear standard solutions but also practical advice for specific challenges, such as ventilation, varying shoe heights (from flat sneakers to boots), storage efficiency, and possibly easy accessibility. Which Pax components (shelves, drawers, baskets) are best suited? How can the interior design be optimized so that as many shoes as possible are stored neatly without making the cabinet look cluttered or overloaded?
I am also interested in the stability, for example when using glass shelves or easily cleaned surfaces. Some shoes can be damp, so should anything special be considered regarding ventilation or should some kind of air circulation be integrated?
I look forward to your experiences and suggestions, including specific product or combination examples.
Emily
BELLA34
3 Apr 2017 12:11
Emily,
I have adapted my Pax wardrobe for shoes using a few simple tricks:
- Installed shelves at various heights
- Added a small ventilation grille at the bottom of the back panel
- For boots, I installed an easy-to-open door on the left side for easier access
In my opinion, nothing more is necessary. It’s worth regularly sorting through your shoes to keep them organized.
TUELBA
4 Apr 2017 07:42
Hello Emily,
I would like to add to the discussion with a detailed guide on how to technically and functionally convert the Ikea Pax wardrobe into a shoe cabinet. I will explain the process step by step.
1. Analysis and Planning
- First, carefully measure the internal dimensions of the Pax, including width, height, and depth.
- Determine the average size of the shoes you want to store: consider flats, sneakers, sneakers with thick soles, pumps, and boots.
- Also think about accessories such as shoe care products, shoe boxes, or weather protection.
2. Adjusting the Shelves
- Use adjustable shelves made of sturdy engineered wood or wood composites.
- Plan for lower, narrower compartments for flats, medium-height sections for sneakers, and taller shelf areas for boots.
- For especially heavy shoes, select shelves with a load capacity of at least 25 kg (55 lbs).
3. Ventilation and Moisture Management
- Moisture is a crucial factor when storing shoes.
- If possible, remove or perforate the back panel in the lower part of the cabinet. Ventilation holes should be designed to prevent dirt or insects from entering.
- I recommend installing small ventilation grilles or vents that allow airflow but block dust ingress.
- Alternatively, you can use silica gel packets or activated charcoal inside the cabinet to control odors and moisture.
4. Drawers and Baskets
- Use wire or plastic baskets for shoe accessories and smaller shoes.
- Drawers are less suitable because they often occupy fixed space and do not provide good ventilation.
5. Door Design
- Consider whether to use standard wooden or glass doors, or doors with ventilation elements.
- Doors should close securely but not be airtight.
6. Accessibility
- Add pull-out compartments or pivoting shelves to improve visibility and access.
- Avoid overloading to prevent shoes from becoming crushed.
7. Safety and Stability
- Check the anchoring of the Pax unit to the wall, especially if storing heavy amounts of shoes.
- Avoid overloading individual compartments to prevent warping.
8. Practical Tips
- Label compartments or boxes for better organization.
- Clean and air out shoes before storing them.
I’m curious about the size of your Pax version and whether you plan to use doors or keep it open. Which types of shoes do you mostly have? This way, I can tailor my advice even better.
TUELBA
