ᐅ How can Ikea Hemnes furniture be repaired if the corners are damaged?
Created on: 5 Jan 2016 13:07
IzakleHello everyone, I have a problem with my Ikea Hemnes furniture piece, specifically with damaged corners on a cabinet. The corners are not only visually affected but are also slightly cracked in some areas, which concerns me because it might affect the structural integrity. Now my question is: How can Ikea Hemnes be repaired if the corners are damaged? Are there any special techniques or materials that are particularly suitable to restore both the appearance and stability as best as possible? I would appreciate any ideas, even if it’s just a tip for a simple repair at home. Thanks in advance!
Hello Izakle, your issue with the damaged corners on the Hemnes is unfortunately not uncommon, as the solid wood used combined with the corner joints can be vulnerable to impact. In general, there are some proven options you can consider:
- For superficial scratches or small dents, wood filler or a color-matched furniture touch-up marker work well for repairs.
- For broken or cracked corners, it is advisable to lightly sand the area before repairing and then use wood glue and, if necessary, wooden dowels or corner brackets for added stability.
- If a corner piece is completely broken off, replacement parts, which Ikea sometimes supplies, can help, or you can try securing the damaged part with wood glue and, if needed, small screws.
I recommend first checking carefully whether the stability is actually affected before starting a more extensive repair. If you like, I can also give you tips on color matching so the repair is less noticeable.
Hello Izakle, I would like to go into more detail regarding the repair of damaged corners on Ikea Hemnes furniture, as there are some important details to consider. You mentioned that the corners are partially cracked and damaged. First of all, I recommend carefully checking the type of material: Hemnes is mostly made of untreated pine wood, which is relatively soft and therefore sensitive to impacts or moisture.
I suggest the following repair process:
- Step 1: Clean the damaged corner thoroughly, remove any loose wood fibers or splinters, and lightly sand the edges to help the wood glue adhere better.
- Step 2: Apply a high-quality wood glue (PU glue is very strong in this case) generously to the damaged areas. If the gap is larger, you can use chipboard or small wood pieces as filler material.
- Step 3: After gluing, clamp the corner with clamps or bar clamps so that the glue cures under pressure. This is important for stability.
- Step 4: Once the glue has dried, sand everything smooth. Now comes the aesthetic part: for smaller repairs, you can use wood filler to even out any irregularities. Then, use paint or furniture wax to match the surface appearance.
One important note: Ikea furniture is usually lacquered or oiled. For Hemnes, you can apply a suitable furniture oil afterward so that the repaired corner matches the rest of the piece in both color and texture.
[pquote=Izakle, post: n6l0o9, member: XXX]The corners are not only visually affected but are partially slightly cracked, which concerns me as it could impact the stability.[/pquote]
Here you should carefully test how unstable the corner actually is. If the structure is still solid, a cosmetic repair is sufficient; otherwise, use the clamping and gluing methods described.
Do you have exact measurements or can you specify the depth and extent of the damage? Depending on that, we can also look into suitable repair kits or replacement parts.
minKarson6 Jan 2016 11:25Hello Izakle, I had the same problem. I simply used wood filler, filled it in, sanded it after it dried, and then treated it with furniture oil. If stability is critical, you can also apply wood glue behind the corner and clamp it with a screw clamp. This way, the shape stays intact and it looks neat.
To efficiently repair damaged Hemnes corners, I recommend a systematic approach:
- Stability assessment: Determine whether the damage is only superficial or if load-bearing elements are affected.
- Materials and tools: Use high-strength wood glue (PU glue), fine-grain wood filler, and fine sandpaper (grit 120-180).
- Preparation: Remove loose parts, clean the surface, and lightly sand it to optimize adhesion.
- Clamping: Use clamps to secure the area while the glue cures.
- Finishing: Choose a furniture oil or wax in a matching color to seal and blend the surface.
If the corner is beyond repair, I suggest contacting Ikea for replacement parts. They offer so-called "Hemnes corner elements" as replacement options, which can be easily swapped.
Please observe careful drying times and avoid applying direct stress during the curing phase to prevent further damage.
