I am currently planning to reorganize my home office and am considering using the Ikea PAX system as the basis for an efficient and flexible office shelving unit. My idea is to use the storage not only for binders and books but also for various office supplies, electronics, and possibly smaller equipment. However, I have a few questions:
- How can the PAX systems be adapted effectively for office use without primarily resembling a wardrobe?
- What kind of interior fittings (shelves, drawers, inserts) are recommended for quick access and optimal organization of office materials?
- Does anyone have experience integrating cable management or small work surfaces into this system?
I want to avoid a cluttered workspace and am looking for practical advice on how to make the modular furniture as functional as possible for office purposes. Thanks in advance for your input!
Hello barbar,
your idea to use Ikea’s PAX system for office organization is definitely practical if configured correctly. In general, I recommend:
- Shelves at different heights to optimally store binders and documents and allow flexible adjustments.
- Internal drawers or inserts for small items like pens, paper clips, or cables.
- Special inserts made of metal or plastic boxes to store hardware such as charging cables or adapters separately.
Regarding cable management: although there are no official PAX cable grommets, a simple solution is self-adhesive cable clips or drilling holes in shelves to guide cables in a controlled way.
It is important to consider the depth of the modules when planning: common depths are 35 or 58 cm (14 or 23 inches), with 58 cm (23 inches) offering more storage space but making the furniture bulkier.
In conclusion, PAX works well if you pay attention to the choice of internal fittings and possibly combine it with accessories from other series. This way, the cabinet remains suitable for office use and doesn’t look like a typical wardrobe.
KAMERON schrieb:
PAX works well if you pay attention to the choice of interior fittings and possibly combine it with accessories from other series.I basically agree with that, but I think it’s important to critically consider whether PAX is really the ideal solution for an office. Many use it because of its modular design, but it mainly comes from the wardrobe sector.
I know cases where the depth or height of the shelves is simply oversized – this can lead to a lot of wasted space. Also, sliding doors or opaque fronts can sometimes be impractical in an office because quick visibility and access are often needed.
Wouldn’t a combination of open shelving with flexible drawer modules from an office furniture series be more effective?
I’m interested to hear if anyone here has already experienced the limitations of PAX in an office environment or if there are methods to work around them.
BLAKEO schrieb:
Wouldn’t a combination of open shelving with flexible drawer modules from an office furniture series possibly be more effective?That’s a good point. I actually tend to keep some elements open as well, since I prefer visual access to my working materials. However, the advantage of PAX is its flexibility and relatively high load capacity.
KAMERON schrieb:
Regarding cable management: Although there are no official PAX cable grommets, a simple solution is adhesive cable clips or drilling holes in the shelvesExactly, I’ll probably have to create a custom solution here, as I want to house some network devices in the cabinets. Thanks for the tip.
I’m thinking of configuring the system with a mix of partly closed and partly open compartments to combine organization with easy accessibility. Has anyone had experience with combinations of glass doors or open compartments in the PAX for office use?
Additionally, I plan to integrate some office equipment into the cabinet (e.g., a small printer or scanner). What are your recommendations regarding the load-bearing capacity of the shelves and whether additional reinforcement is needed?
Hello barbar and everyone interested,
I have been using PAX for my home office for a few years and can share some experiences:
- It’s best to combine open shelves with some closed compartments: open sections for frequently used folders, so you can access them quickly, and closed ones with doors (glass or wood) to avoid dust and create a calmer appearance.
- For technical equipment like printers, I recommend sturdier shelves from the series, which according to Ikea can hold up to 25 kg (55 lbs). If you have heavier devices, it’s better to check whether additional supports are necessary.
- For cable management, I cut small openings in the back panels and ran cables through flexible rubber grommets – this looks tidy and doesn’t permanently damage the furniture.
- Internal drawers or smaller pull-outs are great for small items that tend to get lost during daily office use.
One last tip: use the PAX planner online to test your configuration in advance. This way you can optimize heights, depths, and accessories and avoid purchasing mistakes.
If you like, I can also share examples from my setup.
