ᐅ How can I transport Ikea Metod cabinets during a move without damaging them?
Created on: 2 Oct 2017 08:17
kikla
kikla
2 Oct 2017 08:17
Hello everyone, I’m preparing for a move and have a problem: How can I transport Ikea Metod cabinets without causing damage? Some of the cabinets are already assembled, but I don’t want to take them apart completely because that would require a lot of time and effort. However, I also don’t want to risk doors or carcasses getting damaged due to shifting during transport. Does anyone have experience with how to best secure and protect these relatively large, fairly flat pieces of furniture? I’m especially interested in tips on padding, fastening, and transporting them in a truck or station wagon. Thanks in advance!
maureo
2 Oct 2017 09:03
It is best to empty the cabinets and secure the doors with masking tape. Wedges are recommended between the carcasses, and use ratchet straps to hold them in place. This prevents any shifting.
meole
2 Oct 2017 10:27
I completely understand your concern; I went through the same stress last year. I tried to take apart as much as possible back then, but sometimes I couldn’t because I simply didn’t have the time. What helped me was padding all the edges with thick blankets and pushing everything tightly together. Still, I was worried, but the furniture made it through just fine. Keep your spirits up, it will definitely work out for you too!
PULAU
2 Oct 2017 12:15
Here are some recommendations for transporting Ikea Metod cabinets: - Always secure the doors to prevent damage from shocks. - Either fully disassemble the cabinets or at least remove the doors and shelves. - For transport, use cushioning materials such as foam padding, blankets, or bubble wrap between the furniture parts. - Use straps to stabilize the cabinets and minimize movement. - Use a well-padded transport vehicle, preferably with a smooth loading surface. Tight transport can cause pressure marks.
dabasi
2 Oct 2017 13:05
Oh, I love these kinds of DIY challenges! When I moved last time, I almost completely took apart my Metod cabinets – removed the doors and shelves. This way, I could stack the carcasses lying down and protect them with thick blankets. Tip: Ratchet straps with padding around them make a huge difference! Hope it works out as well for you, fingers crossed!
tolokau
2 Oct 2017 15:42
Here is a structured guide to protect your Ikea Metod cabinets during transport: 1. Empty the furniture: Remove all loose items and personal belongings. 2. Remove doors: Take off doors and drawers to prevent swinging or damage during transport. 3. Padding: Wrap doors and shelves in blankets or bubble wrap to avoid scratches and dents. 4. Protect cabinet boxes: Make sure the cabinets do not touch each other directly; use foam pads or blankets as spacers. 5. Securing: Use straps to firmly fasten everything together and prevent shifting. 6. Transport vehicle: Load the furniture so that it remains stable and cannot fall over. Ensure a clean loading surface and enough space. If disassembly cannot be avoided, document each step for easier reassembly. This helps prevent unnecessary time loss.
