ᐅ How can I safely transport Ikea Metod cabinets during a move?
Created on: 2 Nov 2015 09:17
Sineo
Sineo
2 Nov 2015 09:17
I am about to move and would like to transport my Ikea Metod kitchen cabinets as carefully as possible. Since these cabinets are quite delicate—especially the shelves and back panels—and some need to remain fully assembled, I am wondering how to best secure them and protect them from damage.
Some of the cabinets are already assembled, while others I can still disassemble, although I want to minimize this as reassembly is quite time-consuming.
What experiences do you have with moving Metod cabinet units? Which methods and materials (e.g., padding, coverings, fastenings) work best to prevent scratches, breaks, or warping?
I am also very interested in tips for careful loading and unloading, as well as securing them in the moving van. Thanks in advance!
minKarson
2 Nov 2015 09:46
I would disassemble everything and transport it as flat as possible. Carefully remove the back panels and pack them well. Use bubble wrap or blankets for protection. If assembled, generously cushion with moving blankets.
TEBILO
2 Nov 2015 11:29
Hello Sineo,
Your question is very well formulated, which shows that you have a good understanding of the issue. Metod cabinets are indeed quite delicate. Here is a more detailed guide on how I would proceed:
- If possible, remove at least the doors and drawers. These parts are often the first to get damaged during transport.
- The back panels are usually made of thin MDF board and can easily chip. It’s best to take them out and protect them separately with bubble wrap or blankets.
- The shelves are typically held in place by dowels and screws, but they can bend during transport if not secured. Therefore, fix the shelves with painter’s tape to prevent slipping before moving.
- For assembled cabinets, use protective padding such as moving blankets and cushion the corners with foam or special edge protectors.
- Always transport cabinets in an upright position, never lay them flat. This prevents stress on the shelves and avoids warping.
- When loading into the vehicle, place the cabinets to minimize movement and secure any gaps between items.
Does it make sense for you to already know how many cabinets will remain assembled? There are additional details depending on the cabinet type.
Sineo
3 Nov 2015 07:53
TEBILO schrieb:
Make sure to always transport cabinets upright; never lay them flat.
Thank you, that’s a very important tip! Some of my cabinets are freestanding units (60cm by 60cm (24 inches by 24 inches)) and are difficult to disassemble. I was considering transporting them lying down to save space in the van, but I will definitely avoid that now.
minKarson schrieb:
If assembled, then generously cushion them with moving blankets.
I have some old blankets here, but what is the best way to secure them to the cabinets? Simply tie them with ratchet straps, or should I also use stretch wrap to hold them in place?
Regarding padding inside the cabinets: Should I reinforce the shelves with, for example, cardboard sheets? That would provide extra protective layers against deformation.
V
van_pe
3 Nov 2015 11:45
Secure ceilings with stretch film; that works best. Cardboard sheets for reinforcement are helpful but not absolutely necessary as long as you transport the cabinets upright.
flota
3 Nov 2015 14:10
I would like to add that it is very helpful to completely empty cabinets before moving and to remove the back panels. These back panels are usually simply glued or stapled and can break during handling. If you decide to leave the back panels in place, be sure to place additional padding behind them.
For securing ceilings: ratchet straps are effective but try to avoid excessive pressure that could scratch the surfaces. It is better to use wide straps with protective layers or soft bands.
Another option is to cover hinges and moving parts with masking tape to prevent scratches during transport.
