ᐅ How can I stabilize IKEA Metod cabinets to prevent them from wobbling?
Created on: 16 Oct 2018 08:17
dara48Good morning everyone, I recently assembled several IKEA Metod cabinets. Despite careful assembly, I have noticed that the cabinets wobble slightly, especially when I lean on them or when they are somewhat loaded. This feels unsafe, and I want to avoid the structure deteriorating over time or even tipping over. My question to the community is: How can I stabilize and secure the IKEA Metod base cabinets against wobbling without making major structural changes? Are there any proven methods, special fasteners, or tricks to improve the stability of these cabinets? I would really appreciate your experiences and tips.
Hello dara48, I’m quite familiar with this issue! 😅 Metod cabinets are generally stable, but a bit of wobbling can happen, especially on uneven floors or if they aren’t firmly fastened to the wall. Here are some important points: - Always screw cabinets securely to the wall - Adjust the feet precisely to compensate for unevenness - If you want to increase stability, consider adding a strip or stainless steel brackets on the inside Sometimes, bonding the cabinets together with assembly adhesive or using special connecting screws designed for furniture can also help. This turns individual cabinets into a solid unit. Hope this helps for now! 😊
I’m happy to provide a brief step-by-step guide for stabilizing IKEA Metod cabinets:
- First, carefully adjust the leveling feet so the cabinets don’t noticeably wobble on one side.
- Then, make sure to secure the cabinets to the wall using the included wall brackets; pay close attention to the wall type (e.g., choose appropriate anchors).
- After mounting to the wall, connect the cabinets to each other on the sides, depending on how many cabinets are lined up.
- For additional stability, use angle brackets or special metal braces that can be screwed under the countertop or between the cabinets.
Common mistake: underestimating the importance of wall mounting—it significantly relieves stress on the cabinets. So definitely use the supplied fastening points!
Hello dara48, I see that your question is very practical, and I would like to add a small tip:
Often, you only notice after installation that the floors are not completely level. If the adjustable feet are not placed on a perfectly flat surface, it can lead to wobbling. Therefore, I recommend:
- Check the entire floor with a spirit level directly at the kitchen installation site.
- If the floors are uneven, you can stick a thin piece of foam rubber or similar material under the feet, or use a special leveling washer.
Additionally, it is essential to retighten all screws after a few days. Especially the connections between cabinets can loosen slightly as the wood moves or the cabinets are handled.
Finally, reinforcing the entire structure with metal brackets mounted inside can help. These brackets remain mostly hidden but provide solid stability.
