ᐅ How can I stabilize IKEA Metod cabinets to prevent them from wobbling?
Created on: 16 Oct 2018 08:17
dara48
Good morning everyone, I recently assembled several IKEA Metod cabinets. Despite careful assembly, I have noticed that the cabinets wobble slightly, especially when I lean on them or when they are somewhat loaded. This feels unsafe, and I want to avoid the structure deteriorating over time or even tipping over. My question to the community is: How can I stabilize and secure the IKEA Metod base cabinets against wobbling without making major structural changes? Are there any proven methods, special fasteners, or tricks to improve the stability of these cabinets? I would really appreciate your experiences and tips.
Klakar
17 Oct 2018 09:04
If the floor is only slightly uneven, simply adjust the legs and secure the cabinets to each other and to the wall. If you glue the cabinets together or use additional brackets, the wobbling is almost completely eliminated.
TANBI
17 Oct 2018 09:59
Use feet, screw into the wall, and fasten the cabinets. This is the minimum required. Nothing more is needed unless the floor is extremely uneven.
tutan
17 Oct 2018 12:17
I like it when I have a bit of hands-on freedom with things like this 😄 The small corner braces on the inside help a lot and provide subtle, solid support without affecting the outside appearance. Especially when assembling the cabinets.
And yes, construction adhesive is a good friend that is often underestimated! Just apply it carefully and hold the cabinets in place as long as the adhesive needs to set, so everything stays rock solid.
dara48
17 Oct 2018 16:05
Thank you to everyone who took the time to engage so thoroughly with my issue. I think I will first carefully check and optimize the leveling feet and wall mounting. Then I will add brackets inside to better connect the individual cabinets.
I have also discarded the idea of using a plywood board, as I prefer to level the floor directly and rely on the feet. Additionally, I will apply construction adhesive carefully to create a permanent bond.
Your advice has really helped me better understand the problem and approach it more effectively.
