I am about to move and would like to transport my Ikea Metod kitchen cabinets as carefully as possible. Since these cabinets are quite delicate—especially the shelves and back panels—and some need to remain fully assembled, I am wondering how to best secure them and protect them from damage.
Some of the cabinets are already assembled, while others I can still disassemble, although I want to minimize this as reassembly is quite time-consuming.
What experiences do you have with moving Metod cabinet units? Which methods and materials (e.g., padding, coverings, fastenings) work best to prevent scratches, breaks, or warping?
I am also very interested in tips for careful loading and unloading, as well as securing them in the moving van. Thanks in advance!
flota schrieb:
Cover hinges and moving parts with masking tape to prevent scratches during transport.That sounds reasonable. Would you also recommend completely removing the hinges during the move, or is taping them sufficient?
Regarding the back panels: Some cabinets have tongue-and-groove back panels, which are not easy to remove. In that case, I’d rather rely on padding behind them.
Additionally, I’m curious how you secure the cabinets when loading them into the truck. For me, some boxes are so large that there are barely any gaps – but I’m concerned that if things shift during transport, it could damage the cabinets.
Wow, this is really a hot topic! 🙂
A year ago, I moved my entire kitchen with Metod cabinets and can only say: patience and plenty of padding are key!
I emptied all the cabinets and removed the back panels, which saves a lot of stress. I left the door hinges on and securely taped them with painter’s tape.
For protection, I used thick moving blankets, which I fixed in place with packing tape – it holds really well!
It’s also important not to scratch the floor of the transport vehicle while loading, as this can cause scratches on the bottom of the cabinets. We laid down a rubber mat and leaned the cabinets against each other so nothing would slip.
Thick boxes or cushions fill the gaps and prevent movement.
Even though it takes longer, disassembling helps avoid frustration, but the combination of padding, securing each piece individually, and careful loading really makes a big difference!
Thumbs up if you manage to move everything without damage!
noge58 schrieb:
For protection, we used thick moving blankets, which I secured with packing tape – it holds really well!Great, thanks for the tip about the packing tape. That’s exactly the info I needed!
noge58 schrieb:
We laid down a rubber mat and leaned the cabinets against each other so they wouldn’t shift.That sounds very practical. Do you happen to know how thick moving blankets should ideally be to provide good protection? Is 2 cm (about 0.8 inches) padding enough, or should it be thicker?
Also, I’m wondering whether I should place the high-quality cabinet carcasses outside for transport or load them towards the back of the truck. Thanks for any further advice!
