ᐅ How can I safely transport IKEA Metod kitchen cabinets during a move?
Created on: 15 Aug 2023 08:37
Henny
I am planning to move next month and intend to take my IKEA Metod kitchen units with me. Since these are fairly sturdy but quite bulky pieces, I want to make sure they don’t get damaged during transport.
My question is: How can I safely transport IKEA Metod kitchen units during a move?
What preparations are recommended to avoid scratches, breakage, or deformations? Are there any specific techniques or packing materials that have proven to be especially effective?
I would appreciate any tips on disassembly, padding, and loading, especially since I experienced in my last move that kitchen units can easily suffer damage if they’re not properly secured.
GALEO4
15 Aug 2023 12:46
I find it interesting how often people here present disassembly as THE solution, without considering that assembling Metod units can be extensive and time-consuming. Sometimes, the freshly assembled kitchens are more stable than individually packaged modules—at least as long as the furniture is properly secured.
theo63 schrieb:
I am somewhat skeptical about that. Storing them upright makes sense to place the weight on the frame, but especially with Metod cabinets, which often have large, thin particleboard side panels, there is a risk that they can be easily damaged if the load is uneven.
This brings me to the question of whether it might be more practical to transport the furniture carefully in its assembled form? With padding between the units and enough ratchet straps? Of course, this increases the volume in the van, but it results in fewer disassembly damages and saves effort. What do you think?
V
vin_leo
15 Aug 2023 13:02
GALEO4 makes a good point. Sometimes less is more—especially when under time pressure. If you are transporting a Metod kitchen already assembled, you should definitely keep the following in mind:
- Padding on all contact surfaces to prevent abrasion
- Tie-down straps at several points, but not too tight to avoid deformation
- Possibly use aids like foam corner protectors or edge guards
This way, even a larger cabinet can be moved safely. Of course, space is an issue, but if you have a large van, it is doable and can work well.
kieran
15 Aug 2023 13:38
Objectively, the best method of transport depends on several factors:
- The size and total weight of the kitchen furniture
- The availability of transport options (vehicle size, loading area)
- The availability of materials for padding and securing
- The individual’s skill level for disassembly and assembly
In general, Metod modules are relatively easy to dismantle, which simplifies transportation.
In a professional move, the kitchen is usually fully disassembled, and the parts are securely loaded individually.
The compromise between the effort of taking it apart and the risk of transport damage must be assessed on a case-by-case basis.
My advice: Make a list of all units and rate them as either “easy to transport” or “better left assembled.” For the “easy to transport” units, make sure to completely dismantle them. For the others, reinforce the padding and handle the transport carefully.
SANMAR
15 Aug 2023 14:22
I can understand Henny well – moving the kitchen is usually quite stressful. I once had a similar situation. What helped me was not dismantling everything alone. Especially with Metod kitchens, it’s important to keep track of everything so that all the parts fit back together afterwards. If you have helpers who have some experience or at least steady hands, it can increase the confidence when dismantling and packing.
The emotional strain should not be underestimated either, seeing how much has to be taken apart. Remember to schedule breaks for yourself and organize the parts in a way that makes them easy to identify later.
farGlen
15 Aug 2023 14:41
One simple tip: use plastic wrap, like stretch film, to tightly wrap the individual modules – this protects them from dirt and keeps the cushioning in place.
Also, always have a roll of adhesive tape on hand for quick repairs or reinforcements.
Henny
16 Aug 2023 07:53
Thank you for the many helpful suggestions!
From everything I have read, I believe carefully disassembling the furniture is almost unavoidable if I want to properly protect it. I will try to take everything apart systematically and clearly label the pieces.
For packing, I plan to use bubble wrap combined with furniture blankets and will definitely package the delicate fronts separately.
What method would you recommend for loading? Should I place bubble wrap over all the parts and then secure them directly with ratchet straps? Or should I wrap them tightly first and then secure them? How closely should the parts be placed together?
I have rented a van with a large loading area, but better safe than sorry.
