ᐅ How can I retrofit IKEA Metod soft-close systems?
Created on: 10 Aug 2015 18:43
Marben
Marben
10 Aug 2015 18:43
I am planning to retrofit soft-close systems in my existing IKEA Metod kitchen units. The cabinets are all already installed and in use, but the doors and drawers currently close without any damping, which becomes annoying over time with regular use.
My question is: Which types of IKEA soft-close systems can be easily retrofitted without requiring major modifications to the existing fronts or carcasses? Are there any differences between the Metod doors compared to the standard drawers?
I am also interested in how the installation works technically, whether specific tools or drillings are needed, or if there are maybe attachments that can simply be clicked in.
I have already tried to find information through various manuals and forums, but so far the details seem quite fragmented and sometimes contradictory. Perhaps someone here can help with assembly tips, material recommendations, or practical experience on how to make this retrofit durable and straightforward.
Thanks in advance!
Gaupeo
10 Aug 2015 19:22
You need the appropriate soft-close fittings from IKEA for Metod doors that match the hinge. Simply align the old hinge, attach the fitting with screws, reattach the door, and you’re done. For drawers, there are soft-close runners that you can replace. The tools required are standard screwdrivers and possibly a cordless drill. The drill holes are already pre-made.
leebi7
11 Aug 2015 07:38
Marben schrieb:
The cabinets are all already assembled and in use, but the doors and drawers close without any soft-closing mechanism yet.
If you already have pre-assembled Metod cabinets, retrofitting soft-close systems is generally quite feasible, but it requires careful selection of the components. For doors, it’s best to use the original Metod soft-close adapters, which are specifically designed for the Metod hinges. These adapters are screwed onto the cabinet frame, often in the same position where the hinge itself is mounted, so only minimal adjustment is needed.
Keep in mind that you first need to remove the doors to easily install the soft-close adapters. Installation is done with one or two small screws per adapter. It’s important to ensure that the hooks or guides are aligned correctly during installation so that the soft-closing function works effectively.
For drawers, there are dedicated soft-close runner rails that must match the existing ones. Usually, the entire runner rail has to be replaced with the soft-close version; screwing it in using the existing holes is generally not a problem because IKEA uses standardized holes across all systems.
IKEA usually includes detailed installation instructions or you can find them through their customer service. Tools needed: Phillips screwdriver, possibly a cordless drill with low torque, and maybe a spirit level for final adjustment.
To be sure, check the model numbers of your hinges and runner rails to buy compatible soft-close components. There are also retrofit kits from third-party suppliers, but their fit can vary.
If you want detailed guidance on the exact steps, feel free to provide more information about your model or photos of the hinges, and I can offer more targeted help.
ladali
11 Aug 2015 10:12
leebi7 schrieb:
For doors, it is best to use the original Metod soft-close fittings, which are specifically designed for Metod hinges.
That is correct. Additionally:
- The soft-close attachments for Metod are designed to allow easy retrofitting without major modifications to the cabinet carcass or door front.
- For Metod drawers, there are special soft-close runners that are compatible with the standard fixing points and provide smooth drawer movement.
- An important point before purchasing is to check compatibility, as the Metod series has undergone minor changes over the years.
- During installation, it is advisable to use the existing screw holes, as this ensures stability and simplifies assembly.
No major carpentry skills are required; a simple Phillips screwdriver, possibly a cordless drill, and a bit of time are sufficient.
A targeted retrofit significantly improves handling quality and thus also the lifespan of the cabinets. Therefore, it is a worthwhile investment.
Enrico4
12 Aug 2015 21:47
Marben schrieb:
The cabinets are all already installed and in use, but the doors and drawers still close without soft-closing mechanisms
To add my input:
I personally retrofitted soft-close hinges and drawer slides on a Metod kitchen. It is important to proceed systematically:
- Check the existing hinges for model and production year to obtain compatible soft-close adapters.
- For drawers, identify the current type of drawer slide and select the corresponding soft-close version.
- When installing, pay attention to alignment and adjustment; often the soft-close components need to be mounted slightly offset for the damper to work effectively.
- Remove the door or drawer, carry out the installation, and then carefully fine-tune the settings.
Using non-original parts increases the risk of poor performance. Also, be careful not to overtighten screws during installation to avoid damaging plastic components.
In general, retrofitting is straightforward as long as you have some DIY skills and the correct parts.
