ᐅ How does the retrofit of IKEA Platsa soft-close doors work?
Created on: 8 May 2015 10:12
Davedeo
Davedeo
8 May 2015 10:12
Hello everyone, I am currently considering retrofitting soft-close functionality to my existing IKEA Platsa cabinet doors. I have the classic version without damping and am wondering how the retrofitting process works exactly. What parts are needed, where are the dampers installed, and are there any special considerations during the retrofit, such as specific screws or spacing? Additionally, I would like to know if adding soft-close to Platsa doors is generally straightforward or if there are any limitations. Who has practical experience and can explain the process step by step? Thank you in advance!
PIN66
8 May 2015 10:45
Hello Davedeo,
First of all, to give you an overview: Retrofitting soft-close mechanisms on IKEA Platsa doors is definitely doable, but it requires precise work and, most importantly, the correct soft-close kit that matches the hinges being used.
Here’s how it works in detail:
- First, check the existing hinges. If they are simple overlay hinges, you can retrofit soft-close dampers designed specifically for these hinges.
- IKEA offers separate soft-close damping mechanisms which can either be screwed directly onto the hinge arms or, depending on the model, mounted on the inside of the door.
- The correct spacing during installation is crucial; otherwise, the soft-close function won’t work properly or the door may stick later on.
- When attaching the dampers to the hinge arms, it’s important to pay close attention to the positioning of the screws and the height, as this affects the trigger force of the soft-close mechanism.
- Recommendation: Before tightening everything firmly, hold the parts in place and test the function first.
One more tip: Make sure to have the right drill bit or screwdriver, as IKEA sometimes uses special screws in their kits. Check the instructions in the soft-close kit carefully; they include measurements and installation notes for the ideal positioning.
I hope this gives you a good first overview. If you like, I can also send you some guides or tips on how to measure the correct placement.
NoValentin
8 May 2015 11:05
You need the soft-close retrofit kit from IKEA, attach the dampers to the hinge arms, and install them according to the instructions. Then check the adjustment and, if necessary, fine-tune it.
Ryder35
8 May 2015 11:17
Retrofitting soft-close usually means: buying soft-close dampers, keeping the old hinges, and attaching the dampers to the hinges. Precise alignment is important; otherwise, the door will not close smoothly.
nesau3
8 May 2015 12:33
I upgraded my Platsa doors with soft-close hinges three weeks ago, and it worked perfectly! You just need to measure carefully and not screw too fast, then the damping works great! Good luck – I'm sure you can do it 😊
CHRISTOP33
8 May 2015 14:42
Hey Davedeo! Installing soft-close mechanisms on Platsa doors is really a nice upgrade – it improves the cabinet quality and saves you from slamming doors 😊. Small tip: make yourself a coffee beforehand, because once you know where to place the dampers, the time will fly by. They are definitely adjustable, so don’t worry if it’s not perfect the first time. Have fun with the installation!
