ᐅ How can I renovate the appearance of my BILLY bookshelf?
Created on: 13 Nov 2015 14:03
Meone
Hello everyone, I want to refresh the look of my Billy shelf since it doesn’t look as new after several years of use, and I would like to adapt it to a more modern interior style. Specifically, I’m interested in which materials and techniques are best suited to change or enhance the surface without having to completely disassemble the shelf. Tips on preparation, such as sanding or priming, as well as the advantages and disadvantages of painting versus applying a veneer or film, would also be very helpful. I look forward to your suggestions and experiences!
Lyndon55
14 Nov 2015 14:09
Meone schrieb:
How long should you ideally wait between layers?
In general, I recommend waiting at least 3 hours at room temperature, preferably 6 hours, to ensure a complete drying process. This prevents so-called re-fatting, where the next layer does not adhere properly. In between, you can also do a very light sanding with very fine sandpaper to smooth out any unevenness.
nausu
14 Nov 2015 14:50
One more practical tip: If you plan to paint your shelf in a bright color, start with a white or light primer. This ensures better color coverage, especially with dark colors or unusual shades. It prevents the original wood or melamine color from showing through.
Meone
15 Nov 2015 08:41
Thanks to everyone for the helpful answers! The tips on preparation and drying of the paint layers are especially useful for me. One last question: Do you have any recommendations for specific primers or paint brands that have proven effective on melamine? Or are the standard DIY store products generally sufficient nowadays?
CHENNE
15 Nov 2015 09:26
Generally, high-quality primers from specialized retailers are recommended, for example from brands like 'Aqua Stop' or 'Rust-Oleum'. Products from hardware stores are often cheaper, but adhesion can vary, especially on melamine surfaces. In these cases, it is worth investing in a special solvent-free plastic primer designed for smooth surfaces.
Lyndon55
15 Nov 2015 10:03
Meone schrieb:
Do you have recommendations for specific primers or paint brands?
I have been using the adhesion primer from 'Zinsser' (surface leveling primer) for years, which works very well on smooth surfaces. It provides an even and durable bond between melamine and paint. The paints from 'Clou' and 'Caparol' are often water-based and are well suited for furniture.
KOLAU
15 Nov 2015 11:12
I can also highly recommend Zinsser. It works reliably on various plastic surfaces, including melamine. Above all, adhesion is noticeably improved.
