ᐅ How can I renovate the appearance of my BILLY bookshelf?
Created on: 13 Nov 2015 14:03
Meone
Hello everyone, I want to refresh the look of my Billy shelf since it doesn’t look as new after several years of use, and I would like to adapt it to a more modern interior style. Specifically, I’m interested in which materials and techniques are best suited to change or enhance the surface without having to completely disassemble the shelf. Tips on preparation, such as sanding or priming, as well as the advantages and disadvantages of painting versus applying a veneer or film, would also be very helpful. I look forward to your suggestions and experiences!
lideo
13 Nov 2015 20:01
I painted my Billy bookshelf with chalkboard paint. This allows you not only to change its appearance but also to write or draw on it individually. However, proper preparation and several coats are necessary.
Lyndon55
13 Nov 2015 20:47
A few tips on how to proceed:
1. Empty the shelf and work in a well-ventilated area.
2. Clean the melamine surface with warm water and dish soap, then degrease with alcohol.
3. Lightly sand with 180-grit sandpaper to roughen the surface.
4. Apply a special primer for plastic/melamine surfaces, such as zinc spray or adhesion primer.
5. After drying, apply the desired finish with several coats of water-based acrylic paint or acrylic lacquer.
Alternative:
- Carefully cut vinyl or furniture foil and smooth it down with a squeegee, paying special attention to heating and pressing the edges.
Common mistakes include applying paint layers that are too thick and insufficient preparation, which can lead to peeling.
Meone
14 Nov 2015 09:32
CHENNE schrieb:
When sanding, be sure to use fine-grit sandpaper (grit 180-220)
Thanks, that sounds reasonable. Are you planning to sand the edges of the shelves as well, or just the surfaces? Are there differences in how they should be treated?
Lyndon55 schrieb:
After drying, apply the desired finish with acrylic or water-based acrylic paint in several coats.
How long should you ideally wait between coats?
Sinan-meo
14 Nov 2015 10:47
Regarding the above questions: The edges can also be lightly sanded, but care must be taken not to damage the melamine. To achieve good adhesion, a very light sanding is often sufficient. Between paint coats, a drying time of at least 2-4 hours should be allowed, preferably overnight if possible. This ensures each layer is stable and the surface becomes even.
KOLAU
14 Nov 2015 11:18
With membranes, it is important to press the edges firmly and, if necessary, gently warm them with a hairdryer. This significantly improves adhesion. When painting, keep a close eye on the edges, as chipping often occurs there.
chenlen
14 Nov 2015 12:35
Meone schrieb:
Are you planning to sand the shelf edges as well, or just the surfaces? Are there differences in how they should be treated?
The edges are more delicate and often made of thick plastic or ABS edge banding. It is recommended to use very fine sanding or just lightly roughen the surface to improve adhesion without visibly damaging the material. Heavy sanding can cause the finish to chip later or create uneven areas.
