ᐅ How can I prevent IKEA Metod cabinets from wobbling?
Created on: 24 Jun 2020 18:37
Ivy49
Ivy49
24 Jun 2020 18:37
I recently assembled my IKEA Metod kitchen cabinets, but unfortunately, I noticed that the cabinets wobble slightly despite being put together correctly. I really made sure to follow the instructions carefully. I am particularly interested in how to permanently prevent the wobbling of the Metod cabinets, as I am concerned that large cabinets might become unstable or even tip over over time.
What measures – besides securely screwing them in – specifically help to reduce or completely eliminate this wobbling? I have considered different wall fastenings and additional braces, but I am unsure if this is the right approach. It would also be helpful to know if there are any special tips or mounting materials at IKEA or generally available that improve the stability of the cabinets.
I am looking forward to your experiences and advice!
BLAMAU
24 Jun 2020 18:52
Hello Ivy49,
my advice: Make sure all the feet are properly adjusted so that the cabinet stands level. Then firmly secure it to the wall – anchor the supplied wall brackets correctly. This is the most effective way to reduce wobbling.
Nauman5
24 Jun 2020 19:09
Hey Ivy49 😄,
I know the problem! What helped me was placing small rubber pads under the feet to even out any irregularities. And yes, don’t underestimate the wall mounting, otherwise the whole thing will wobble like a dance partner without rhythm.😉
P.S.: If you properly adjust the cabinet doors as well, the whole setup will feel even more stable!
Katau
24 Jun 2020 20:04
Hello Ivy49,
I completely understand your concerns. The wobbling in Metod cabinet units often results from uneven floors or insufficient wall mounting. Therefore, my advice:
- Use a spirit level to check if the cabinets are properly aligned.
- Adjust the cabinet feet individually; some IKEA feet are easy to fine-tune.
- Always use wall brackets—at least two per cabinet—and secure them with appropriate wall plugs.
- You can also use small spacers or wedges between the cabinets and the wall to avoid pressure on sensitive areas.
If your floor is very uneven, some hardware stores offer special leveling feet that are more robust.
If you have any further questions, just let me know.
Joshbe
25 Jun 2020 07:23
It is important that the stability of IKEA Metod cabinets primarily depends on the correct use of the included wall brackets and the adjustment of the leveling feet. Additionally, reinforcement with extra cross braces can be helpful, especially for larger cabinets or long kitchen runs.
Summary of my recommendations:
- Precisely align the leveling feet so that the cabinet rests fully on the floor.
- Use high-quality wall plugs suitable for the wall material (e.g., heavy-duty anchors for concrete).
- Attach the wall brackets according to the assembly instructions, with at least two brackets per cabinet to minimize the risk of tipping.
- Optional: Install metal cross braces or connector brackets between individual cabinets to join them into a rigid unit.
These measures should significantly reduce or eliminate wobbling.
Nauman5
25 Jun 2020 09:11
Joshbe schrieb:
- Optional: installation of metal cross braces or connector brackets between individual cabinets to create a rigid unit.
Exactly that! It basically creates a small cabinet group that holds together. 😆 No wobbling at all! Especially when the kitchen is large, you’ll handle this with ease.
