ᐅ How can I reduce the assembly time when installing IKEA Metod kitchen units?
Created on: 24 Dec 2023 14:37
Can33
Can33
24 Dec 2023 14:37
Hello everyone, I am planning to assemble my new IKEA Metod kitchen soon and want to minimize the installation time. Are there any proven strategies or important tips on how to approach the assembly systematically to save time? I am particularly interested in the preparation steps on site, handling of the individual units, and any special tools that might speed up the process. It would also be helpful if you could share your experiences with common pitfalls to avoid unnecessary delays. Thanks in advance for your support!
Filippo
24 Dec 2023 16:52
Hello Can33,
I completely understand your question, as assembling IKEA Metod kitchens can be quite time-consuming depending on the preparation. To effectively reduce assembly time, I recommend a systematic build process in several steps:
- First, carefully and thoroughly check all parts. The original IKEA packaging can quickly get mixed up, so organize the components by cabinet, doors, drawer fronts, and accessories.
- An often underestimated aspect is having the right tools: A cordless drill with adjustable torque settings is essential. Additionally, I use a screwdriver for fine work, a hammer with a plastic head (to avoid damaging surfaces), and a spirit level to perfectly align the cabinets.
- When assembling the cabinets, it’s important to closely follow the step-by-step instructions. Avoid impatience, as tightening screws too early often makes later adjustments more difficult.
- Important: It’s best to complete one cabinet fully before starting on the next. This minimizes error tracking and rework.
- Common pitfalls include missing screws, incorrectly installed connectors, and inaccurate alignment, all of which can significantly delay the assembly. It’s a good idea to check all screws against the instructions in advance and set them aside if necessary.
- Finally, if possible, work with a partner. One person holds, the other screws – this also improves time management.
How would you rate your DIY skills so far? Have you already had experience with furniture assembly? Then I can tailor my tips even more specifically.
Jukin
25 Dec 2023 09:18
Filippo schrieb:
A cordless screwdriver with adjustable torque settings is a must.
I completely agree! Especially with knock-down fittings, the correct torque is crucial to avoid damaging the Lamello and eccentric connectors.
Filippo schrieb:
It’s best to fully complete one cabinet before starting the next.
I would like to add to this point: Sort the screws and fittings according to the instructions at the beginning and divide them into small trays or boxes, so you don’t have to search for screws during each step. This saves a lot of time and frustration.
It can also help to clear the work surface in advance and have enough space to lay everything out.
If you like, you can also review the instructions offline beforehand or even have a digital PDF on hand – this way you can quickly check the next steps anytime.
How large is your kitchen project exactly? Just base cabinets, or also wall cabinets and hanging systems?
nolan
26 Dec 2023 08:42
To save time, make sure to sort all screws and use a cordless drill with an adjustable torque setting. Do not tighten too much, as this can cause assembly errors. It is also best to have someone available to assist.
Filippo
26 Dec 2023 20:11
nolan schrieb:
To save time, definitely sort all screws and use a cordless drill with adjustable torque settings.
Exactly, I’d like to emphasize this again, as screw management is an area where many people lose a lot of time.
Jukin schrieb:
Sort the screws and fittings at the start according to the instructions and separate them into small trays or boxes
I would add that even the order of assembly following the instructions is important to avoid later adjustments and corrections, which can be very time-consuming.
Another tip: if you prepare some parts during furniture transport and position the components accordingly, you can avoid multiple unnecessary trips.
My question to Can33: Do you have any special requirements, such as a complex corner solution or many drawers, that might make the assembly more challenging?
