ᐅ How can I safely design Ikea PLATSA furniture for a child's room?
Created on: 22 Jan 2018 18:27
riluri
riluri
22 Jan 2018 18:27
I am planning to furnish the children’s room with Ikea Platsa furniture but have some concerns regarding safety. My main question is: How can I make Ikea PLATSA furniture safe for a children’s room, especially concerning stability, tip-over protection, and preventing injury risks for toddlers?
I am thinking about topics like proper anchoring to the wall, covering sharp edges, or safely storing small parts. Are there any specific tips or proven solutions I should be aware of?
Thank you in advance for your detailed advice!
tadi31
22 Jan 2018 19:13
riluri schrieb:
How can I make Ikea PLATSA furniture safe for a child’s room, especially regarding stability, tip-over protection, and preventing injury risks for toddlers?
Hello riluri,
Your question is very important because safety should always come first, especially with children. Regarding the PLATSA series, here are some basic recommendations:
- Wall anchoring: Ikea provides tip-over safety kits with fasteners for many PLATSA units, which should definitely be used. This prevents the furniture from tipping over if children try to climb on it.
- Stability through assembly: Make sure to assemble the furniture exactly according to the instructions and tighten all screws securely. If possible, use additional back panels for increased stability.
- Edge protection: PLATSA furniture generally has smooth and rounded edges, but for small children, you can add soft edge protectors as an extra precaution.
- Safe storage: Small parts and sharp objects should be stored in lockable drawers or boxes.
- Placement: Avoid positioning the furniture directly next to windows or heating units.
Personally, I placed fabric baskets in the lowest shelves for my children, which also provide some additional protection.
If you need more details, I’m happy to help!
O
ONRONA
23 Jan 2018 07:44
riluri schrieb:
How can I make Ikea PLATSA furniture safe for a child’s room, especially regarding stability, tip-over protection, and avoiding injury risks for toddlers?
I want to question whether the standard mounting hardware provided by Ikea is sufficient. Especially for children’s furniture, it should be able to withstand high loads, even if several kilograms (pounds) of weight are applied to one spot—such as when a child climbs on it.
Many Ikea furniture pieces can be assembled quickly, but that does not automatically mean they are safe. My recommendation would be to use stronger wall brackets or heavy-duty anchors in addition, instead of relying only on the thin screws included in the package.
Also, I would avoid stacking or building the furniture too high. It’s better to have multiple smaller units side by side than one tall structure that could easily tip over.
Regarding edge protection: the edges are fairly smooth, but personally, I see more risk from protruding handles or drawer parts that toddlers could bump into.
I’m curious how others view this or if there are reliable test reports specifically evaluating PLATSA furniture for children’s rooms.
FABIAN_DEO
23 Jan 2018 12:36
riluri schrieb:
How can I make Ikea PLATSA furniture safe for a child's room, especially regarding stability, tip-over protection, and preventing injury risks for toddlers?
Hello riluri,
If safety is a priority for you, there are quite a few technical aspects to consider with PLATSA. Here are some detailed recommendations and steps I would suggest:
- Wall mounting: The PLATSA units are versatile, but securing them to the wall is essential. If you use the tip-over safety kits supplied by Ikea, be sure to check the type of wall you are attaching to (plasterboard, concrete, brick) and use appropriate anchors – plastic anchors are rarely sufficient for plasterboard; metal or heavy-duty anchors are better.
- Modularity: When combining multiple PLATSA units, use all the mounting holes and additionally screw the modules together to prevent wobbling.
- Screws & connectors: All parts must be assembled with the recommended screws (usually Phillips or Torx); avoid makeshift fixes. If screws are missing, you can order replacements from Ikea or use universal screws with enhanced grip.
- Edges: Though Ikea PLATSA has mostly smooth surfaces, I recommend applying soft edge protectors near the floor, especially for small children. These are available in foam or soft silicone.
- Handle design: Avoid protruding or sharp handles, as these can easily cause injuries during child movement. Models with flush handle recesses are preferable here.
- Interior fittings: For small items like pens or toys, I suggest using drawer inserts or boxes so nothing is loose and can be swallowed.
It would also be helpful to know the exact dimensions of your child’s room to suggest better furniture configurations. How old are your children and how do they use the space? This can help address potential hazards more specifically.
I hope this helps!
FELOTAU
24 Jan 2018 21:59
riluri schrieb:
How can I make Ikea PLATSA furniture safe for a children’s room, especially regarding stability, tipping protection, and preventing injury risks for toddlers?
I can only share from my own experience that these concerns were very important to me as well. When our daughter was little, I had many plans, but everyday life often teaches you what really works.
What helped us a lot:
- Always securely anchor furniture to the wall, even if it takes extra effort.
- Keep small loose parts out of reach so children don’t put them in their mouths.
- Use corner protectors on all accessible edges – you get used to them quickly.
- Avoid storing items that children can easily pull down in the lower sections.
- Regularly check that screws and fittings are still tight, since many tend to loosen over time.
By the way, I appreciate that you are addressing this topic so thoroughly because the risks are often underestimated. I wish you good luck and hope you find the perfect setup with advice from everyone.
