ᐅ How can I evenly distribute the weight inside a Pax wardrobe?
Created on: 9 Nov 2019 18:37
Bill45
Bill45
9 Nov 2019 18:37
Hello everyone, I recently bought a Pax wardrobe from Ikea and am now facing the challenge of distributing the weight of my clothes and other stored items as evenly as possible. My goal is to ensure the stability of the wardrobe and avoid potential deformation or damage caused by uneven loading. In particular, I am wondering how to best position the heavier items: should they be placed lower down or in the middle? Are there established principles for distributing weight across the individual shelves and important points to consider when filling them? I would appreciate any advice on optimal weight distribution or suitable additional stabilization methods.
LANICOLE
9 Nov 2019 19:05
Hello Bill45, your concern is very important because uneven weight distribution can actually affect the stability of your Pax wardrobe. I would like to offer you a structured approach:
- As a general rule: most of the weight should always be stored at the bottom. This ensures a low center of gravity and prevents tipping.
- Heavy items like shoes, thick boxes of books, or storage bins should be placed on the lowest shelves.
- Middle shelves are suitable for medium-weight clothing, such as sweaters or other folded textiles.
- Light clothing like T-shirts or blouses can be stored at the top.
- Distribute the load evenly on both sides of the wardrobe to avoid overloading one side.
- Assemble the wardrobe exactly according to the instructions, and use the recommended wall fixings, especially for taller models.
Another tip: if you plan to store many heavy items, reinforced shelves or additional support braces might help. The Pax wardrobe already has built-in side panels, but adding extra reinforcements could increase its load capacity.
I hope this helps. If you like, you can briefly describe exactly what you want to store in the wardrobe, and I can give you more targeted advice.
GUSTAVO56
10 Nov 2019 09:44
Hello Bill45, I fully agree with LANICOLE’s question and would like to add some technical details.
First, it is important to know the load limits of the individual shelves – for Pax, this is usually about 15 kg (33 lbs) per shelf when the weight is evenly distributed. If you concentrate heavy items on a small area, it can cause bending or even failure.
A tip: place heavier items on the lower shelves, as already mentioned, to minimize the tipping moment. The tipping moment occurs when a load is applied high up, causing the unit to become unbalanced.
Practically, you can do the following:
- Check the stability of the wardrobe before loading, especially the wall fixings.
- Avoid placing all heavy items on one side – try to distribute the weight as evenly as possible.
- If possible, use large, sturdy boxes or baskets to better distribute the load.
- Make sure the wardrobe itself is properly leveled (using a spirit level) for optimal positioning.
May I ask how tall your Pax wardrobe is and what exactly you plan to store in it? This could help provide a more precise answer.
mopra42
10 Nov 2019 12:11
Hello Bill45, I recommend:
- Heavy items on the bottom.
- Distribute evenly, do not stack.
- Use shelves according to load capacity.
- Secure the cabinet to the wall.
Done.
