ᐅ How can I combine IKEA Metod kitchen units with other kitchen furniture?
Created on: 12 Sep 2023 18:27
rinor35Hello everyone,
I am currently planning my new kitchen and using IKEA Metod as the basic framework. Now I am wondering: How can I combine IKEA Metod with other kitchen furniture without the overall appearance looking uncoordinated?
My main concern is whether I can, for example, integrate individual elements from another brand into the Metod structure without causing issues either in terms of aesthetics or functionality. In my mind, I’m imagining a kind of mix between Metod cabinets and maybe some distinctive fronts or sideboards (for example, made of wood or in a completely different style).
Does anyone have experience with this? Are there best practices or things to watch out for regarding dimensions, installation, or design? I would greatly appreciate any advice, especially on how to best balance the technical and aesthetic aspects.
Hello rinor35,
First of all, your question is very good and important if you don’t want to rely on just one system.
In general, IKEA Metod is a very flexible system that works well with other furniture due to its modular construction, as long as you keep a few things in mind:
- Dimensions: Metod units come in certain standard widths (e.g., 60 or 80 cm (24 or 32 inches)), which makes planning easier. Other kitchen furniture should ideally have similar or at least compatible connection dimensions so that nothing looks noticeably misaligned.
- Depth: The depth of Metod cabinets is usually 60 cm (24 inches), but some other furniture may have different dimensions. It helps to consider whether you want to use pieces as countertop units or freestanding elements next to the Metod cabinets.
- Fronts and Materials: Appearance matters as well. If you want to combine different fronts, be sure to pay attention to color tone and material texture. A harmonious contrast can look very nice! For example, metal or wood fronts can complement the smooth Metod fronts very well.
- Assembly Options: Some kitchen manufacturers use different mounting systems. You should check if the furniture can be joined not only visually but also securely. Additional adapters or screws might be necessary.
In summary: Mixing is definitely possible as long as you carefully check the dimensions and consider the designs. Feel free to add more details about your planned furniture, and I or someone else can help you even more specifically.
rinor35 schrieb:
How can I combine IKEA Metod with other kitchen furniture without the overall look appearing mismatched?This is a very interesting question that I would like to explore from a technical perspective.
First, it’s important to measure and plan carefully: Metod cabinets are standardized with a depth of 60 cm (24 inches) and varying widths (20, 40, 60, 80 cm). Other manufacturers often differ in these dimensions, which can result in misaligned edges or uneven gaps when placing the units next to each other. This is often noticeable visually.
My advice: Use the gap between the cabinet fronts and the countertop as a unifying element. If the depths are different, you can work with a suitable countertop or trim pieces to neatly conceal the transitions.
The attachment systems for the cabinets also often differ significantly. IKEA uses screw-in and fastening systems that other manufacturers don’t replicate. Therefore, you should consider not only the appearance but also the structural stability. There are two options here:
- Separate pieces of furniture that visually match but do not need to be rigidly connected.
- Custom-made connecting strips or even DIY solutions for adaptation if you are handy.
From a design perspective, it’s worth adding color accents. For example, a white Metod kitchen with open wooden shelves or rustic sideboards next to it. This breaks up the different styles but still looks deliberately coordinated.
Finally, a question: What is your main goal? Do you simply want to place furniture from different manufacturers side by side, or are you aiming to create integrated elements that are structurally connected?
If you provide a bit more information, I’d be happy to offer more detailed suggestions.
In short: Pay close attention to the correct alignment of the base height and cabinet depths. Different heights will otherwise result in unsightly steps.
Front colors should ideally be similar, or you can intentionally go for contrasts. Technically, the mountings are usually not compatible, so it’s better to fix the furniture separately.
benon schrieb:
In general, IKEA Metod is a very flexible system that, due to its modular design, combines well with other furniture if you keep a few things in mind:I totally agree, especially since I have a kitchen with Metod cabinets alongside freestanding units from different manufacturers. It’s important to align the heights. For example, if you want to place tall cabinets from another brand next to Metod units, you should make sure the base height and top edges match.
I also had wooden fronts custom-made by a carpenter and fitted onto IKEA carcasses, which worked well because the carcasses are standardized, while the fronts were individually designed.
For assembly, I added small metal brackets to securely connect the furniture pieces.
If your space isn’t a perfect fit, I’d recommend making minor adjustments rather than trying to physically connect everything structurally, as that can become complicated in the end.
I would like to add that the connection between baseboards and trim is often underestimated.
When combining IKEA Metod with other furniture, the baseboard requires special attention because different furniture pieces often have varying baseboard heights and depths. This can be visually disruptive if the transition is not executed carefully.
A clean solution is either a continuous baseboard that visually unites all the furniture or the use of baseboards with matching colors to harmonize the transitions.
On the other hand, you should pay attention to the thicknesses of countertops and work surfaces – when combining different furniture, uneven thicknesses can otherwise result in unsightly edges or overhanging surfaces.
In short: measure dimensions, heights, depths, and especially baseboard heights carefully. This makes all the difference.
